Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Showing results 1 to 18 of 18
Search took
0.01
seconds.
Search:
Posts Made By:
firechickenman
Forum:
Pontiac - Race
01-06-2024, 10:01 AM
40
Sick Week 2024
3,116
Posted By
firechickenman
It's kinda like playing Tetris. It sure helps...
It's kinda like playing Tetris. It sure helps that I don't have a fuel cell or batteries in the trunk! If you need to change wheels for track and street, it almost requires a trailer although I have...
Forum:
Pontiac - Race
11-06-2023, 02:09 PM
20
Joining the 9 Sec Club!
1,785
Posted By
firechickenman
Great job Lee! Your persistence has paid off!
Forum:
Pontiac - Race
08-03-2023, 08:58 PM
38
More Carnage From Norwalk
2,588
Posted By
firechickenman
Nothing too crazy... about 6500 on the shifts and...
Nothing too crazy... about 6500 on the shifts and through the lights.
Forum:
Pontiac - Race
08-03-2023, 08:38 AM
38
2,588
Posted By
firechickenman
Thanks! I feel my shortblock lasted beyond it's...
Thanks! I feel my shortblock lasted beyond it's expectations. I'm just aggravated I didn't upgrade to a forged crank when I should have. Of course, you read all the comments how tough the factory N...
Forum:
Pontiac - Race
08-02-2023, 10:11 AM
38
2,588
Posted By
firechickenman
Thanks...it's going to sting a little but it will...
Thanks...it's going to sting a little but it will be back bigger, better, stronger, lighter and hopefully faster!
Forum:
Pontiac - Race
08-02-2023, 08:30 AM
38
2,588
Posted By
firechickenman
.980" dia. wall thickness is .150". They are the...
.980" dia. wall thickness is .150". They are the JE pins that came with my SRP pistons.
Forum:
Pontiac - Race
08-02-2023, 08:20 AM
15
FRONT Plate only or Front Plate and Mid Plate
886
Posted By
firechickenman
I believe "better" would be front and mid plates....
I believe "better" would be front and mid plates. It takes all the twisting force away from the block. I've been running solid motor mount and a rubber trans mount for years. I feel like I've...
Forum:
Pontiac - Race
08-02-2023, 07:50 AM
38
2,588
Posted By
firechickenman
Yes, I forgot to add that. Factory N crank that I...
Yes, I forgot to add that. Factory N crank that I have raced since 2013 and it was in a race build before that. I now know it should have been cycled out for a forged crank....
Forum:
Pontiac - Race
09-12-2021, 10:45 AM
12
60ft times
1,563
Posted By
firechickenman
Thanks! The converter is a custom 10" PTC....
Thanks! The converter is a custom 10" PTC. Flashes to 5000 but still works well on the street. 3.73 gears and 275/60R15 puts me right at 6500 throughthe traps.
Forum:
Pontiac - Street
03-21-2021, 04:52 PM
33
Largest solid roller for REAL street car.
3,345
Posted By
firechickenman
It's a TH350
It's a TH350
Forum:
Pontiac - Street
03-20-2021, 10:15 AM
33
3,345
Posted By
firechickenman
The set-up I'm running is very easy on parts. I'm...
The set-up I'm running is very easy on parts. I'm running the Comp Endure-X lifters on their XE Street Roller lobes 266/272 and about .650 net lift with HS 1.65's. I run the K-motion K-800 springs...
Forum:
Pontiac - Street
01-07-2021, 02:31 PM
11
Ebay fabricated valve covers
1,464
Posted By
firechickenman
I've had a set on my Firebird since 2014. I like...
I've had a set on my Firebird since 2014. I like them a lot especially for the price. I cut a couple holes in them to add grommets and breathers. They seal really nice with a set of TIP 5/16"...
Forum:
Pontiac - Race
09-30-2020, 01:41 PM
37
Time for a Torque Converter??
6,289
Posted By
firechickenman
I'll bet that launch with the 8" converter did...
I'll bet that launch with the 8" converter did feel a little different! That 60' change should have made more difference in your ET but that converter is too loose killing your down track...
Forum:
Pontiac - Race
02-15-2020, 11:14 AM
17
M/T ss radial tires?
1,457
Posted By
firechickenman
I have a set. They work great for me. As good as...
I have a set. They work great for me. As good as the old ET Street Radial and the ET Street Radial Pro but I'm not making that much power either. Another option would be the ET Street R. It's...
Forum:
Pontiac - Race
02-06-2020, 02:15 PM
7
Cam Swap Thoughts Lunati Voo-Doo to Comp Solid Roller
1,315
Posted By
firechickenman
You would see a night a day difference with the...
You would see a night a day difference with the cam swap especially with the right converter. I'm pretty sure a "Jim Hand" converter would not be near enough. Like Jay S said, you would need a...
Forum:
Pontiac - Race
01-19-2020, 11:39 PM
19
electric fan ? HP difference
5,841
Posted By
firechickenman
If it's one like this, it cost 25 hp at 5100 rpm...
If it's one like this, it cost 25 hp at 5100 rpm in the Engine Masters test.
Forum:
Pontiac - Race
11-06-2019, 03:02 PM
5
Vacuum Pump vs. Header Evac?
2,072
Posted By
firechickenman
I went to header evacs from a PCV system a few...
I went to header evacs from a PCV system a few years ago. It didn't seem to improve my ET any but it does make me feel better about not introducing any oil into the intake tract through a PCV valve....
Forum:
Pontiac - Race
12-18-2013, 02:48 PM
44
new combo to track...please analyze
2,082
Posted By
firechickenman
If you're not wanting to run less than 11.50, you...
If you're not wanting to run less than 11.50, you could probably do that without changing anything major. Especially if you like the conservative gear and converter that you have now for the street....
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
09:32 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
