Forum: 70-73 Firebird & TA TECH
04-16-2023, 06:49 PM
I will never understand why high dollar...
I will never understand why high dollar restorations can't get the front end painted correctly.The bottom of the nose is wrong. Picky,sure...but just has a different look vs how the factory wanted .....
01-03-2023, 10:05 PM
01-03-2023, 09:33 PM
04-02-2022, 07:22 PM
03-20-2022, 10:48 AM
70-71 TA Fenders
Been a while since I saw original 70-71 TA fenders for sale, whats the consensus of their current value?? Have an original pair that I am never going to use. Pain to ship which is why I never sold...
03-15-2022, 03:54 PM
02-19-2014, 07:30 PM
02-18-2014, 12:00 PM
Tim-
Chris at that shop you are talking about...
Tim-
Chris at that shop you are talking about knows well how to do the boosters. They have to be polished before plating.Actually I sent him the polishing tools he uses. I am assuming Bloomington...
02-17-2014, 10:10 PM
02-17-2014, 08:30 PM
The boosters are number coded,at least the 1970...
The boosters are number coded,at least the 1970 and 71 model years were.1970 is 0426 and 1971 is 1957.. I bet 1972 has its own number as well. Plus the yellow zinc most do these in is too shiny. 72...
02-17-2014, 08:22 PM
02-15-2014, 02:05 AM
01-31-2014, 04:40 AM
01-29-2014, 03:18 PM
"a 71 or 72 H.O.should be = 70 RAIV"
you are...
you are kidding correct? 71 or 72 HO's being as valuable as a IV?? oh dear... you really are lost if you believe that..then again, guess you own a 72 and are...
01-22-2014, 01:16 AM
01-21-2014, 07:53 PM
Norwood is correct on values.. With Pontiacs...
Norwood is correct on values.. With Pontiacs apparently becoming the current pumped GM brand at the auctions(latest BJ results as evidence) these components are only going to get more expensive..
01-21-2014, 07:36 PM
transam1972... are you ok?? do you have anyone...
transam1972... are you ok?? do you have anyone close who can check on you?? I am by no means trying to pick on you..but you are posting threads that seem ..well trying to be polite, but crazy.. what...
01-21-2014, 03:45 PM
Help on two items '70 Firebirds
Hey Guys.. I think I know this answer but thought I would bounce it off the board to confirm. Here are my two questions:
1.70 FB's only had a single rear shelf speaker on the drivers side,correct? ...
01-20-2014, 05:06 PM
01-04-2014, 03:03 AM
Please guys.. The seller did not say number...
Please guys.. The seller did not say number matching, he just said a real TA.That is a real TA with a NOM 455 with a stupid later shaker or something. There are no "super secrete" pre production TA's...
01-02-2014, 02:45 PM
Please post the OER part number and the primer...
Please post the OER part number and the primer part number you have used. Would like to use the same you used..Looked for OER hi solids and all I found was aluminum color?? Appreciate your help..
12-30-2013, 09:09 PM
12-30-2013, 09:58 AM
12-30-2013, 01:57 AM
the washers and bolts were manganese...
the washers and bolts were manganese phosphate(black phosphate) , and if memory serves me well, they are like 1.125" diameter, all the current repos are 1.25" diameter( or visa versa,not at home to...
12-14-2013, 06:03 PM
CompCams has a roller cam ,something like...
CompCams has a roller cam ,something like 226/230, which is a step above the stock 68 cam that runs quite well in a 455. The roller cam is a drop in component but you will have to buy their roller...
