Forum: Pontiac - Street
10-19-2023, 09:05 PM
10-17-2023, 10:06 PM
06-29-2023, 07:49 PM
I have a 1971 Cutlass with 18x8 fronts with...
I have a 1971 Cutlass with 18x8 fronts with 245/45r18 and 18x9.5 with 275/40r18 Nitto 555g2's. These tires spec out on Nitto site as 26.65" and i wouldnt want to go any shorter to fill out the...
06-28-2023, 10:46 PM
06-28-2023, 10:44 PM
06-28-2023, 10:31 PM
BFH means Big Friggin Hammer. Leave the castle...
BFH means Big Friggin Hammer. Leave the castle nut on the ball joint, then hit the side of the spindle where the ball joint passes through. The shock will allow the spring pressure to pull the ball...
Forum: 61-66 Big Pontiac TECH
06-16-2023, 07:39 AM
01-03-2023, 11:37 AM
12-04-2022, 01:06 AM
Forum: EFI Tech
11-13-2022, 08:27 PM
I feel the same as above about the pro Flo 4. ...
I feel the same as above about the pro Flo 4. Once you price out a cheap TBI unit like a sniper, the dual sync distributor and an intake you are right in the same ballpark as the edelbrock. With...
10-04-2022, 09:11 PM
08-24-2022, 06:56 PM
Forum: Exhaust TECH
05-08-2022, 08:42 PM
Forum: Exhaust TECH
05-05-2022, 06:10 PM
As far as the Dynomax recommendation, what you...
As far as the Dynomax recommendation, what you want for quiet is the 17749 long case super turbos. I have regular 14" ones on my Catalina now and will be switching up soon after riding in a friend's...
04-28-2022, 05:15 PM
I can't help you with the rear speakers, but as...
I can't help you with the rear speakers, but as far as the dash speaker goes, you can go one of a couple different ways. I used one of the DVC 4x10's that has separation for left and right channels....
04-23-2022, 09:10 AM
Not OP, but I have used the stock 9v ignition...
Not OP, but I have used the stock 9v ignition wire to trigger a relay for steady 12v to an HEI in the past. It's just one way to be sure that you are getting full battery voltage without hacking up...
Forum: LS Talk
04-23-2022, 01:52 AM
Yeah. I personally have a 370" LQ9 with AI...
Yeah. I personally have a 370" LQ9 with AI ported cathedral heads, cam motion 227/232 cam, 1 7/8" headers, truck intake, stock truck TB, built 4l65e trans, 2600 stall converter, 3.73 gears in my 71...
Forum: LS Talk
04-04-2022, 03:23 PM
he's talking about DI not having constant fuel...
he's talking about DI not having constant fuel spray to keep the back of the valves clean. Catch cans are cheap and easy and make sure the PCV system doesnt suck in excess oil vapor that will gum up...
03-15-2022, 08:49 AM
03-05-2022, 05:34 PM
Same opinion as above. Keep 2 bolt mains, get...
Same opinion as above. Keep 2 bolt mains, get inexpensive forged rods and forged pistons, and upgrade to 1.65 rockers for a really good understressed street combination that will last a long time. ...
03-04-2022, 06:54 PM
11-29-2021, 02:25 PM
Forum: EFI Tech
07-07-2021, 11:14 PM
i'm running a pro flo 4 as well. it's on a 462...
i'm running a pro flo 4 as well. it's on a 462 with 96 heads and a mild ultradyne 280/288 cam. initial setup is crazy simple and it fired right up and drove really well after only warming it up and...
04-04-2021, 01:05 AM
01-28-2021, 05:48 PM
