Forum: SOLD Parts
03-18-2021, 04:16 PM
Forum: SOLD Parts
03-18-2021, 11:46 AM
FWIW...
Guys, I've known Tony for over 24 years. He was a member here in the past but when the site changes format he got locked out due to PW issues.
He is a straight shooter and knows Pontiacs very well....
Forum: 73-77 A-body TECH
03-07-2021, 09:12 PM
Forum: THE LOBBY
02-13-2021, 09:07 PM
I read this and felt like an idiot for not...
I read this and felt like an idiot for not thinking of that myself. I wasn't lucky enough for it to be so simple though. Blew a little air through the tube ahead of the filter too thinking it could...
Forum: THE LOBBY
01-25-2021, 12:14 PM
I will say this, free of political bias...
As a fifty year old male who is hoping like hell to hold on to my last little bit of common sense (I question myself every day), I find it reckless to go...
Forum: THE LOBBY
01-03-2021, 09:22 PM
Forum: THE LOBBY
01-03-2021, 08:21 PM
Wouldn’t go near it.
It has not been time...
It has not been time tested for side affects for the minimum of 2 years.
It’s shown some nasty side affects on lab animals.
This comes from my father who’s a retired...
Forum: THE LOBBY
01-03-2021, 05:48 PM
Forum: The Body Shop TECH
01-02-2021, 10:26 AM
If you are not comfortable welding in a patch...
If you are not comfortable welding in a patch then you could blast it and fill the area with 3M panel adhesive. Not as good as welding in new metal but the repair will likely outlast you. Apply a...
12-31-2020, 06:40 PM
I'm no expert by long shot but my opinion is,...
I'm no expert by long shot but my opinion is, that would be quite a bit of filling with weld. l think you would wind up doing a lot more welding and grinding in the end than you would using a patch....
12-31-2020, 03:21 PM
I'd be taking that glass out and looking at the...
I'd be taking that glass out and looking at the entire area as a whole. Then you can decide on a plan. That might be the worst spot and that would be a good thing. If you've got more rot, now is the...
12-31-2020, 03:17 PM
Check this site out. ...
Check this site out. http://www.beldenspeed.com/rust-patch-panels They specialize in rust around windows. I would call them as they may have pre-made panels for your car even though they don't...
12-31-2020, 01:41 PM
12-31-2020, 09:50 AM
Welding in new metal is always going to be the...
Welding in new metal is always going to be the best solution, if you can do it or have it done. Here is a series of photos showing how a rust hole in the rear window channel of my off topic car was...
12-31-2020, 09:39 AM
12-31-2020, 08:32 AM
12-31-2020, 07:44 AM
If you have access to a mig welder I strongly...
If you have access to a mig welder I strongly advise that you make some simple
patches from sheet metal. A window channel is the easiest part to hand form a patch for. If you can post pictures I...
12-30-2020, 09:57 PM
Why not just go with fiberglass cloth/mat?
It is not a stress area. It is sand blasted, so the fiberglass cloth/resin will bond real well. Cut to fit, then mix your resin/hardner, dip/saturate...
07-31-2020, 03:40 PM
I'll definitely keep my progress up to date. I...
I'll definitely keep my progress up to date. I previously had a TKO500 in the car behind a mild 455, and I used the factory mechanical linkage with that. I sold the TKO500 after a friend had moved...
Forum: THE LOBBY
03-29-2020, 11:44 AM
Thanks for adding to worthwhile data.
Both me...
Both me and my wife work in healthcare, and she is dealing with COVID-19 patients every day!
The V.A. hospital got the FIRST COVID-19 patient in Louisiana,...
Forum: THE LOBBY
03-22-2020, 01:18 PM
