Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 7
1
2
3
Last
Showing results 1 to 25 of 158
Search took
0.03
seconds.
Search:
Posts Made By:
avman
Forum:
SOLD Parts
06-27-2023, 05:25 PM
12
1965 GTO "parchment" bucket seats FOR SALE NICE!
1,334
Posted By
b-man
Gerald, Click on his username and then click...
Gerald,
Click on his username and then click on send private message. Communication by private message is best and that way you’re not posting so much personal information on the open forums.
Forum:
SOLD Parts
06-27-2023, 03:59 PM
12
1,334
Posted By
Gmax
65 GTO seats
Want to purchase your advertised 65 GTO seats for the $700.00 price.
Please let me know how to proceed.
Forum:
SOLD Parts
06-25-2023, 11:42 PM
12
1,334
Posted By
Gmax
Would like to purchase the 65 GTO bucket seats...
Would like to purchase the 65 GTO bucket seats that you advertised. Please let me know how to proceed. Thanks for your response.
Forum:
SOLD Parts
06-24-2023, 07:32 PM
12
1,334
Posted By
Gmax
Just saw your post on the front bucket seats for...
Just saw your post on the front bucket seats for the 65 GTO.
Are they still available?
Gmax
Forum:
Pontiac - Street
06-05-2023, 01:42 PM
68
Progression Ignition tunes
10,106
Posted By
Formulajones
Up at higher elevations I tend to have the cars...
Up at higher elevations I tend to have the cars running a pinch on the rich side so that when we go down to sea level I don't have to worry about it. The CD ignition helps keep the plugs cleaner...
Forum:
SOLD Parts
05-26-2023, 11:00 AM
12
1,334
Posted By
will slow gto
I agree, this seems like a really good deal for a...
I agree, this seems like a really good deal for a pair of factory buckets with a very presentable set of covers. I think you haven’t had a hit yet because it’s a one year only item (limits the number...
Forum:
Pontiac - Street
11-23-2022, 01:25 PM
68
10,106
Posted By
ta man
It not that hard, not much different than a...
It not that hard, not much different than a normal initial fire up. You don't need it exactly at 10 degrees at first..after the engine is running and warm then it can be set exactly..not much...
Forum:
Pontiac - Street
08-27-2022, 07:22 PM
68
10,106
Posted By
wbnapier
https://progressionignition.com/ The sell...
The sell distributors that allow for timing maps to be created and use via one's smartphone. You can makes all sort of adjustments to timing that would be very...
Forum:
Pontiac - Street
08-19-2022, 08:03 PM
68
10,106
Posted By
wbnapier
Thank you Formula_jg. For whatever reason, I did...
Thank you Formula_jg. For whatever reason, I did not receive the map from you. To date, I have received one table from someone else. I'd like to try to send you one as a test if you let me have...
Forum:
Pontiac - Street
06-06-2022, 09:44 AM
68
10,106
Posted By
lovedemnewfies
I ran a new dedicated 12v power wire. The...
I ran a new dedicated 12v power wire. The distributor is the only part tied into the new power feed.
Forum:
Pontiac - Street
06-05-2022, 09:23 PM
68
10,106
Posted By
Formula jg
Was there a resistor wire in the original points...
Was there a resistor wire in the original points setup? It can cause some weird issues if you use it on the Progression distributor, if I recall there is a special note in the installation...
Forum:
Pontiac - Street
05-05-2022, 10:22 AM
68
10,106
Posted By
Captain Obvious
You're right about the idle. For some reason I...
You're right about the idle. For some reason I had it in my head that it should be around 650, but that is low. It will idle there all day long without loading up. Part of the reason I've had it...
Forum:
Pontiac - Street
03-29-2022, 08:15 AM
68
10,106
Posted By
firechicken
Thanks, my timing requirements changed...
Thanks, my timing requirements changed dramatically when I switched from 6X to Kauffman D ports.
Forum:
Pontiac - Street
03-28-2022, 09:16 PM
68
10,106
Posted By
Formula jg
461/9.7 static comp 6X4 approx. flow 250cfm ...
461/9.7 static comp
850 MD w/annular
T2 w/1” tapered 4 hole spacer
700R4 w/lockup
3:42
Crower solid flat tappet approx. spec w/1.65:
244/252@50
0.525/0.551
112 LSA
Forum:
Pontiac - Street
03-25-2022, 03:56 PM
68
10,106
Posted By
25stevem
A lot of what can be done hinges on these details...
A lot of what can be done hinges on these details that you should post up about your car.
1) CID.
2) compression.
3) Cam.
4) rear gears.
Forum:
Pontiac - Street
03-25-2022, 02:43 PM
68
10,106
Posted By
TA-71
This can be the place to talk about Progression Distributor(s) and to share your ignition tables that work for you and your combination.
I just got my HEI setup and running and would love to see...
Forum:
Pontiac - Street
12-09-2020, 03:03 PM
35
Progression Ignition Distributor Installation
9,065
Posted By
Formula jg
I rec’d my Pro Ignition HEI distributor a couple...
I rec’d my Pro Ignition HEI distributor a couple of weeks ago and the first thing I noticed is how well built it was, even the distributor cap was unlike any I have every purchased over the decades....
Forum:
Members Helping Members
10-28-2020, 07:56 PM
41
New ford 7.3 ford trucks
4,207
Posted By
Chief of the 60's
This is how men towed prior to everyone buying a...
This is how men towed prior to everyone buying a diesel to haul their golf cart around...…………
https://i.pinimg.com/originals/2c/57/1c/2c571c62cfddbe5d3b315e3cdac3f80b.jpg
Forum:
Pontiac - Street
10-14-2020, 01:54 PM
80
428 ho talk
6,669
Posted By
242177P
I've explained this before. 330 hp in...
330 hp in Firebird --->3300 lbs
360 hp in GTO ---> 3600 lbs
390 hp in GP ---> 3900 lbs
Forum:
61-77 GTO, Tempest & LeMans Parts WANTED
10-11-2020, 12:24 AM
9
Used Muncie M20 input shaft wanted (any condition)
1,122
Posted By
propuckstopper
Use a bearing driver tool to install the bearing,...
Use a bearing driver tool to install the bearing, then use the Muncie Input shaft tool to line up the clutch disk. I have an old Muncie shaft, and I find it more accurate than using the cheap plastic...
Forum:
10-10-2020, 08:44 PM
9
1,122
Posted By
stevep
An old socket will work better because you do not...
An old socket will work better because you do not want to be driving the bearing in by the center race.
Forum:
Heating & Cooling TECH
09-27-2020, 06:21 PM
1,420
Sticky:
Chalk up one more for the cast impeller.
261,379
Posted By
HWYSTR455
Keep in mind, when a dual fan setup is giving...
Keep in mind, when a dual fan setup is giving dimensions, the highest point is the fan motors. The highest point on your engine is most likely the water pump snout. That would fit between the fan...
Forum:
09-19-2020, 09:05 AM
1,420
Sticky:
261,379
Posted By
HWYSTR455
Or 'Kickstart My Heart' too! .
Forum:
09-18-2020, 10:07 AM
1,420
Sticky:
261,379
Posted By
HWYSTR455
So 26x16, yeah, you will have to see. I would...
So 26x16, yeah, you will have to see. I would have suggested something like this:
https://derale.com/product-footer/electric-fans/shrouded-powerpacks/dual-powerpacks/16836-detail
It's less...
Forum:
09-18-2020, 06:39 AM
1,420
Sticky:
261,379
Posted By
HWYSTR455
Problem is there are no standards for rating fan...
Problem is there are no standards for rating fan flow, so you can't really tell what the true cfm is. It's like back in the 70s & 80s when auto stereo amps were rated at ridiculous watts. (and were...
Page 1 of 7
1
2
3
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
10:33 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
