Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 6
1
2
3
Last
Showing results 1 to 25 of 149
Search took
0.03
seconds.
Search:
Posts Made By:
1969GPSJ
Forum:
Pontiac - Street
02-11-2024, 01:32 PM
398
Pontiac V8’s: Retrofitting GM Roller Lifters
71,642
Posted By
Stan65
Singleton is correct, most cams have the top of...
Singleton is correct, most cams have the top of the lobe (max lift) the same height from the cam center line. This is roughly .010” less then the journal diameter. This means no matter what lift cam...
Forum:
Pontiac - Street
02-11-2024, 01:07 PM
398
71,642
Posted By
Singleton
I don't have the answer, but from another thread...
I don't have the answer, but from another thread from someone that is using them, "To use the HT2148 lifters, cam base circle must be at least 1.135” diameter".
If that is the case, anything less...
Forum:
Pontiac - Street
02-11-2024, 11:24 AM
398
71,642
Posted By
Stan65
I’m still working that out for options, but the...
I’m still working that out for options, but the fallback will be the modified ford spider.
Forum:
Pontiac - Street
02-11-2024, 08:29 AM
398
71,642
Posted By
Stan65
Here’s a picture of the bones on cylinder’s 7 and...
Here’s a picture of the bones on cylinder’s 7 and 8. I had to modify these as I expected because of the difference in the casting in these locations, but they fit and function as expected.
Not...
Forum:
Pontiac - Street
02-09-2024, 02:09 PM
398
71,642
Posted By
tempest1964
Stan, let me know when you are ready to produce...
Stan, let me know when you are ready to produce these. Thanks again.
Tony
Forum:
Pontiac - Street
02-09-2024, 01:02 PM
398
71,642
Posted By
Stan65
Yes sir. Notch is for casting clearance. Will...
Yes sir. Notch is for casting clearance. Will probably have to grind on the rear passenger bone for additional clearance. Will start test fitting these hopefully this weekend. There is a counter bore...
Forum:
Pontiac - Street
02-09-2024, 12:39 PM
398
71,642
Posted By
tempest1964
Those look nice! Correct spacing for Pontiac's....
Those look nice! Correct spacing for Pontiac's. That notch, for casting clearance? I like the fully enclosed much better than the open ended Ford dogbones. Are these hardened? If not, just curious,...
Forum:
Pontiac - Street
02-09-2024, 12:25 PM
398
71,642
Posted By
Stan65
So after a long wait I have the prototype dog...
So after a long wait I have the prototype dog bones made. Hopefully in a few weeks I’ll have more info. Not sure what costs will be if I go forward with mass producing some. There are definitely...
Forum:
Pontiac - Street
12-03-2023, 07:49 PM
48
Another "atypical" engine question - this time about head gaskets.
2,027
Posted By
Dragncar
AEM has multiple NA systems. The page would not...
AEM has multiple NA systems. The page would not load earlier but just loaded for some reason.
https://www.aemelectronics.com/products/water_methanol/na_high_compression/
Forum:
Pontiac - Street
12-03-2023, 07:45 PM
48
2,027
Posted By
Gach
They do make 120 Proof Vodka..LOL just carry gal...
They do make 120 Proof Vodka..LOL just carry gal of distilled water and a fifth of vodka. Its funny with todays marketing they can sell to allot of still wet behind the ears. It did work pretty good...
Forum:
Pontiac - Street
12-03-2023, 06:54 PM
48
2,027
Posted By
Dragncar
Water injection today is not the same as the old...
Water injection today is not the same as the old Edelbrock Vari-Injections. Technology always moves forward.
I doubt the folks running these modern water-meth injection are saying "don't waste your...
Forum:
Pontiac - Street
12-03-2023, 03:40 PM
48
2,027
Posted By
Gach
Very good plan.
Very good plan.
Forum:
Pontiac - Street
12-03-2023, 03:14 PM
48
2,027
Posted By
Gach
Ok so spill the beans, whats your plans on moving...
Ok so spill the beans, whats your plans on moving forward. ?
Forum:
Pontiac - Street
12-03-2023, 12:36 PM
48
2,027
Posted By
HWYSTR455
Yeah, I tried it, didn't do squat. Now meth may...
Yeah, I tried it, didn't do squat. Now meth may work, but dunno, haven't tried it, but know some of the GN guys have had success.
As for cams, you would have to switch to a big enough one that...
Forum:
Pontiac - Street
12-03-2023, 12:01 PM
48
2,027
Posted By
Gach
I’ve tried to water ejection two different...
I’ve tried to water ejection two different applications, don’t waste your money. Or should I say flip a coin.
Forum:
Pontiac - Street
12-03-2023, 10:48 AM
48
2,027
Posted By
Jay S
Pontiac greatly over rated their compressions on...
Pontiac greatly over rated their compressions on all their engines. If I were you, if your interested in switching heads, get the 85cc KRE d ports. The compression would be in the upper 8s then, and...
Forum:
Pontiac - Street
12-03-2023, 09:27 AM
48
2,027
Posted By
HWYSTR455
The last iron head engine I did was in the late...
The last iron head engine I did was in the late 90s, and ran that until mid-2000s or so (I've done many Pontiac engines. Many.). 400, 16 large valve heads, surface clean up, TRW pistons, .030 over....
Forum:
Pontiac - Street
12-03-2023, 07:50 AM
48
2,027
Posted By
Cliff R
"428 HOs didn't have special pistons." The...
The last 428 that I built here was a 390hp version. It had special exhaust manifolds, oil filter adapter, and something different about the harmonic...
Forum:
Pontiac - Street
12-03-2023, 07:42 AM
48
2,027
Posted By
Cliff R
NEVER for any reason use a thick gasket to lower...
NEVER for any reason use a thick gasket to lower compression on one of these engines for pump gas. Here I will not for any reason build one of these engines with over .040" quench. These crappy...
Forum:
Pontiac - Street
12-03-2023, 07:20 AM
19
Car shut off during U turn
1,144
Posted By
steve25
I had a battery issue like that once where the...
I had a battery issue like that once where the hold down rotted out and learned a big lesson in grounding the motor to the body.
My battery had got thrown up on to the fender during a tight turn...
Forum:
Pontiac - Street
12-03-2023, 05:04 AM
48
2,027
Posted By
242177P
Forum:
Pontiac - Street
12-03-2023, 02:32 AM
48
2,027
Posted By
Gach
Long story short many running 10.1 compression...
Long story short many running 10.1 compression with iron heads no issue. On pump gas. Just takes right cam.
Forum:
Pontiac - Street
12-03-2023, 02:21 AM
48
2,027
Posted By
Gach
Another thing dramatic compression, should be no...
Another thing dramatic compression, should be no more the 8. I’ll bet if you run the numbers with your cam your above that. Digimatic compression is whats important. I know I know there’s a whole...
Forum:
Pontiac - Street
12-03-2023, 02:10 AM
48
2,027
Posted By
Gach
Definitely by the sounds of you mixing gas...
Definitely by the sounds of you mixing gas together getting rid of the detonation your probably around 10-1 10.25. If you end up with zero deck then maybe .060 heads gasket.
Forum:
Pontiac - Street
12-03-2023, 01:55 AM
48
2,027
Posted By
Gach
The other thing the cam thats in your now, was...
The other thing the cam thats in your now, was kind of for leaded gas, not gas that has 10% ethanol. In other words when gas was good gas. So from your description you’re having serious detonation....
Page 1 of 6
1
2
3
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
12:34 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
