Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 20
1
2
3
11
Last
Showing results 1 to 25 of 500
Search took
0.10
seconds.
Search:
Posts Made By:
Hotrodjohn71
Forum:
Pontiac - Street
09-20-2023, 08:55 PM
4
'67 Vacuum Dashpot Adjustment
528
Posted By
gto4ben
The adjustment instructions are in the Pontiac...
The adjustment instructions are in the Pontiac Chassis Service manual. 64,65,66, & 67 manuals all target ~1050 RPM [(1030 to 1080RPM) after the Throttle Return Check (dashpot) vacuum hose is...
Forum:
Pontiac - Street
09-20-2023, 04:04 PM
4
528
Posted By
67drake
John, I saw your post over on the HAMB. There are...
John, I saw your post over on the HAMB. There are a couple carb gurus on this site that might be able to answer the question if you post it here.
I’d start a new thread
Forum:
64-65 GTO Tempest & LeMans TECH
09-20-2023, 02:15 PM
10
Vacuum dashpot adjustment
1,678
Posted By
gto4ben
I see that Ames reproduces the '65 4 barrel fuel...
I see that Ames reproduces the '65 4 barrel fuel line (N129A) in steel. It may require the inline fuel filter.
Many moons ago before it was reproduced, I made my own out of steel following the...
Forum:
09-19-2023, 08:02 PM
10
1,678
Posted By
gto4ben
I also could not find the source for Goatracer1's...
I also could not find the source for Goatracer1's instructions. When I checked the '65, '66, & 67 Pontiac Chassis shop manuals, the instructions differed although I suspect you get to the same...
Forum:
09-19-2023, 04:19 PM
10
1,678
Posted By
b-man
Your ‘65 326 has the large base Rochester...
Your ‘65 326 has the large base Rochester 2-barrel.
The only engines that used the small base 2-barrel in 1965 would have been the Tri-Power 389 or 421 which used the small base center carb.
Forum:
09-19-2023, 03:34 PM
10
1,678
Posted By
Kenth
Your routing of the fuel line is a good recipe...
Your routing of the fuel line is a good recipe for percolating and vapor bubbles in fuel line.
JMHO
Forum:
Pontiac - Street
09-17-2023, 08:59 AM
13
Is 39-40° total timing too much?
1,030
Posted By
Cliff R
Using an HEI is a game changer with these things....
Using an HEI is a game changer with these things. They tend to have a shorter mechanical advance curve and add a lot more vacuum advance
If I were setting up your HEI for the little 326 I would...
Forum:
Pontiac - Street
09-16-2023, 02:16 PM
13
1,030
Posted By
Joe-Touring
The 326 I run has about that much timing in it....
The 326 I run has about that much timing in it. 18 initial, ~38 mech, 10 vac. But my engine is a 0.040” over rebuild with #143 heads, so comp ratio is prolly in the mid to high 8s. I’d say it runs...
Forum:
Pontiac - Street
09-16-2023, 12:56 PM
13
1,030
Posted By
77 TRASHCAN
Doing a compression test (as mentioned by someone...
Doing a compression test (as mentioned by someone above) is a good idea. It will give you an idea of the dynamics of your new engine.
Having a new (clean) engine can possibly contribute to your...
Forum:
Pontiac - Street
09-16-2023, 11:08 AM
13
1,030
Posted By
steve25
Sorry I missed the part about the full rebuild. ...
If you have not done a cranking compression test then I would do such, just to know what you have and for your own records, because the new time chain...
Forum:
Pontiac - Street
09-16-2023, 11:01 AM
13
1,030
Posted By
nUcLeArEnVoY
19 is way too high for your motor, yes. That...
19 is way too high for your motor, yes. That depends a lot on the compression. For instance, the factory initial timing setting for my 1979 400 is 18 BTDC, and is the setting I use. My engine is...
Forum:
Pontiac - Street
09-16-2023, 10:52 AM
13
1,030
Posted By
Cliff R
19 degrees Initial timing is high for any of...
19 degrees Initial timing is high for any of these engines if they have much compression in them. Total timing a bit high, but I've had a few over the years that were fine in that area.
Timing...
Forum:
Pontiac - Street
09-16-2023, 10:43 AM
13
1,030
Posted By
67drake
Myself, I would put a piston stop in to verify my...
Myself, I would put a piston stop in to verify my true TDC. Your timing mark may be off. No Pontiac I’ve ever owned would want that much initial timing.
On the other hand, I believe in giving the...
Forum:
Pontiac - Street
09-16-2023, 10:40 AM
13
1,030
Posted By
turbo69bird
I’d say pull the plugs and see what they show ....
I’d say pull the plugs and see what they show . If it looks like it’s fat still it’s not likely detonating . That pinging can be hard to hear that’s for sure, a really rich mixture is harder to...
Forum:
Pontiac - Street
09-16-2023, 10:21 AM
13
1,030
Posted By
steve25
19 initial is very high! If you have never...
If you have never yourself replaced the timing chain & gears in this motor then I would preform this test .
Remove all the plugs, removed and back away thd dizzy cap so...
Forum:
Pontiac - Street
09-16-2023, 07:14 AM
13
1,030
Posted By
steve25
You need to be more detailed. Do you have 39...
Do you have 39 to 40 degrees in just mechanical advance, or is this amount seen with your distributors vacuum advance plugged in?
Your 1965 heads are of the closed...
Forum:
Suspension TECH
08-14-2023, 12:12 PM
7
Best cushioned shocks
809
Posted By
rohrt
Since this is such a subjective issue you might...
Since this is such a subjective issue you might want to look into adjustable shocks. I used the single adjustable RideTech's on my 64 Tempest. The single adjustable only effects the rebound rate. ...
Forum:
Suspension TECH
08-14-2023, 11:40 AM
7
809
Posted By
JLMounce
If you want that cushiony, almost floaty ride,...
If you want that cushiony, almost floaty ride, I'd opt for the stock type spiral shocks. They'll do just that.
I've had the Gabriel shocks on my 1969 Firebird and they are fairly supple as well.
Forum:
Suspension TECH
08-14-2023, 11:00 AM
7
809
Posted By
ta6point6
Air shocks will give you the smoothest ride....
Air shocks will give you the smoothest ride. There is a reason they are on Cadillacs and now being put on newer trucks. I had air shocks on the TA and switched to sensatrac and regretted it. The ride...
Forum:
Pontiac - Street
08-06-2023, 01:36 AM
10
Possible starter bendix run-out issue.
488
Posted By
Lemans64
Sounds like either low voltage to the solenoid or...
Sounds like either low voltage to the solenoid or solenoid issue. I put a relay on my wire going to the s terminal on starter so power comes from battery thru rely to s terminal.
Instead go gong...
Forum:
Pontiac - Street
08-05-2023, 07:37 PM
10
488
Posted By
I spiced mine in about 4" from the engine side...
I spiced mine in about 4" from the engine side firewall and took the opportunity to make it plug-able. Now it can double as an under hood starter for adjusting valves. I just unplug it and connect a...
Forum:
Pontiac - Street
08-05-2023, 07:13 PM
10
488
Posted By
Schurkey
Common as dirt. The main reason folks put a...
Common as dirt.
The main reason folks put a "Ford Solenoid" on the fender, is because they don't have sufficient voltage at the starter solenoid end of the "purple wire".
This (photo attached)...
Forum:
Pontiac - Street
08-05-2023, 06:36 PM
10
488
Posted By
I know you said you have good power to the...
I know you said you have good power to the starter but check what voltage you have on the solenoid from the ignition switch. I had an intermittent starter with similar symptoms and after changing...
Forum:
Pontiac - Street
08-05-2023, 04:38 PM
10
488
Posted By
steve25
Well hearing a light click when you turn the key...
Well hearing a light click when you turn the key to start it is the sound of the solenoid closing , but maybe not good enough to flow the current needed to spin the armature .
If you are hearing a...
Forum:
Pontiac - Street
08-05-2023, 04:19 PM
10
488
Posted By
steve25
On the all the occasion’s when the motor does...
On the all the occasion’s when the motor does not crank is it up to normal running temp, or will the issue take place with it cold also?
Page 1 of 20
1
2
3
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
04:49 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
