Forum: THE LOBBY
03-18-2024, 02:51 PM
Forum: Pontiac - Street
02-10-2024, 05:13 PM
I was a bit curious about what sort of...
I was a bit curious about what sort of performance I could get with the non-adjustable valvetrain, and also with a low-compression 87 octane limit.
I've gone 11.2's with flat tappet cam and iron...
02-10-2024, 12:12 PM
01-25-2024, 06:32 PM
01-25-2024, 06:31 PM
People have ran mid/low 12's with that combo,...
People have ran mid/low 12's with that combo, nothing wrong with it. SHOULD blow the tires away anywhere in first gear, and possibly in 2nd.
Either there is a defective part (worn cam lobe, for...
12-25-2023, 01:01 PM
Forum: THE LOBBY
12-24-2023, 12:13 AM
Really sad. I remember him hiring Goathead...
Really sad. I remember him hiring Goathead (Danny Reegan) to install all the audio/video when he was building his house. About 10 years ago a lot of the Houston area auto repair shops rented the...
Forum: Electrical Tech
10-25-2023, 07:41 AM
10-24-2023, 07:48 AM
Forum: Exhaust TECH
10-24-2023, 07:42 AM
09-22-2023, 04:58 PM
Forum: THE LOBBY
08-30-2023, 04:42 PM
08-25-2023, 08:24 AM
Forum: THE LOBBY
08-24-2023, 09:03 PM
Forum: THE LOBBY
08-18-2023, 02:04 PM
08-17-2023, 04:11 PM
Do you have 7/16"-20tpi rocker studs? If so,...
Do you have 7/16"-20tpi rocker studs? If so, then each full turn of the nut is 0.050". How many turns from "zero lash" to "fully collapsed" to you have, and how much preload do you want.
For...
08-15-2023, 08:12 AM
I have a '73 T/A clone. 455, with similar spec...
I have a '73 T/A clone. 455, with similar spec "66" heads. I used the KB347 pistons, which have just enough "dome" (a slightly raised pad, more accurately) to zero out the valve relief, which give...
Forum: Pontiac - Race
08-11-2023, 01:58 PM
Forum: Exhaust TECH
08-10-2023, 12:39 PM
08-07-2023, 11:44 PM
Forum: THE LOBBY
06-29-2023, 11:29 AM
Forum: THE LOBBY
06-28-2023, 05:14 PM
06-22-2023, 08:53 PM
Forum: THE LOBBY
06-10-2023, 08:23 AM
A new GoFundMe page has been started -...
A new GoFundMe page has been started - https://www.gofundme.com/f/for-lisa-and-dave-bisschop-sd-performance?utm_campaign=p_cp+share-sheet&utm_medium=social&utm_source=facebook
For anyone...
Forum: THE LOBBY
06-09-2023, 07:22 AM
