Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 2
1
2
Showing results 1 to 25 of 28
Search took
0.02
seconds.
Search:
Posts Made By:
chiphead
Forum:
Pontiac - Street
03-30-2024, 10:00 AM
11
TH-400 Question
519
Posted By
steve25
The above post makes sense, #9. I pulled out...
I pulled out my info and in terms of any 400 cid TB400 from a A or F body car with a 4 bbl they had 3 different shift point they could have been programmed for.
Forum:
Pontiac - Street
03-15-2024, 01:51 PM
14
TH400 shift kit modifications?
745
Posted By
65 Lamnas
Drop the valve body and take a look at the...
Drop the valve body and take a look at the separator plate. If it's already had a TG kit, you'll notice it on the plate. You're not going to be able to tell if it's had rings or lip seals removed...
Forum:
Pontiac - Street
03-07-2024, 12:32 PM
9
Read my R45S plugs?
703
Posted By
steve25
Info.
Info.
Forum:
Pontiac - Street
03-07-2024, 11:56 AM
9
Read my R45S plugs?
703
Posted By
johnta1
I'd try a R44S plugs and see what they look like...
I'd try a R44S plugs and see what they look like without a lot of idling. Idling makes it really hard to color the plugs correctly.
Forum:
Pontiac - Street
02-08-2024, 02:21 AM
98
8.2 upgrade options
4,331
Posted By
Charlie Brengun
With what those moser 12 bolts cost, I'd take a...
With what those moser 12 bolts cost, I'd take a long hard look at a nicely built 9 inch from a place like quick performance.
Forum:
Pontiac - Street
01-29-2024, 11:45 AM
64
aluminum D vs. round port heads
3,145
Posted By
Steve C.
On the subject of the intake/exhaust flow ratio....
On the subject of the intake/exhaust flow ratio. Here is what Harold Brookshire from UltraDyne said on the subject within a post here on PY:
"On most cylinder heads, whenever I have around a 75...
Forum:
Pontiac - Street
01-28-2024, 10:26 PM
64
3,145
Posted By
i82much
Sometimes I say things and just wish you guys...
Sometimes I say things and just wish you guys would give me the reaction I am looking for ...
Forum:
Pontiac - Street
01-23-2024, 10:59 AM
79
Slack in center link, front end rebuild time?
4,086
Posted By
JLMounce
Looks good! There's just something about new and...
Looks good! There's just something about new and shiny suspension pieces against the crusty weathering of an unrestored car!
Forum:
Pontiac - Street
01-23-2024, 10:19 AM
79
4,086
Posted By
HWYSTR455
In some situations, the upper control arm bump...
In some situations, the upper control arm bump stop needs to be trimmed or shorter. It can limit travel.
Otherwise it all looks good!
Forum:
Performance Parts For Sale/Wanted
01-14-2024, 10:20 PM
1
Late style Bathtub intakes
612
Posted By
tom s
Guys,had breakfast with John this morning and I told him I had a call for one and as I have posted we sold out of both styles.He informed me he has had calls and has started a list.If he gets enough...
Forum:
Pontiac - Street
01-01-2024, 05:27 PM
44
Hyd Roller Lifters
1,938
Posted By
Tim Corcoran
Hyd Roller Lifters
Some interesting info regarding hyd roller lifters on the Butler website
https://butlerperformance.com/n-13499-hyd-roller-lifter-specs-and-information.html
Forum:
Pontiac - Street
12-15-2023, 01:47 PM
14
Main bearing dowels
971
Posted By
400 Lemans
http://www.precisionautomotivespecialists.com/Pont...
http://www.precisionautomotivespecialists.com/Pontiac-V8-Engine-Dowel-Pins.html
Forum:
Pontiac - Street
11-11-2023, 04:33 PM
79
4,086
Posted By
Joe-Touring
From what I've seen, every car is a bit...
From what I've seen, every car is a bit different, so it's difficult to make a blanket statement for ride heights. 1 inch drop springs can do a lot of different things depending on what springs were...
Forum:
Pontiac - Street
09-01-2023, 09:11 AM
10
Driveshaft length, 67 GTO with TH400?
478
Posted By
HWYSTR455
A 1.5" rise in suspension is going to have little...
A 1.5" rise in suspension is going to have little effect on the slip yoke engagement. Probably not even measurable.
Forum:
Pontiac - Street
09-01-2023, 09:09 AM
10
478
Posted By
HWYSTR455
Of course that's not ok. Not only is it not full...
Of course that's not ok. Not only is it not full engaging the splines, it's not fully supported by the tailshaft bushing.
Get a new shaft made, that's the answer. No matter how many times the...
Forum:
Pontiac - Street
07-24-2023, 11:29 AM
21
Low oil pressure, my turn?
1,393
Posted By
steve25
A motor that has low oil pressure due to hurt...
A motor that has low oil pressure due to hurt bearings does not ever go back to having normal oil pressure again, so that's not a option here.
I guess is that you either had a very small sliver...
Forum:
Pontiac - Street
07-12-2023, 02:11 PM
83
Quickfuel 750 DP jetting?
6,975
Posted By
Formulajones
High 13's cruising AFR is perfectly ok. Stoich...
High 13's cruising AFR is perfectly ok. Stoich is only 14:1 with 10% ethanol.
My Z actually cruises in the low to mid 13's and been daily driving it that way for years. Fact is the engine is...
Forum:
Pontiac - Street
07-07-2023, 11:17 PM
83
6,975
Posted By
Tom Vaught
More than one was to "skin a cat". That high...
That high position IFR is screwing things up, though, for you.
I will look at my 3310 stuff and see if I have an extra (used) 3310 metering block.
Forum:
Pontiac - Street
05-10-2023, 11:22 AM
83
6,975
Posted By
Tom Vaught
Holley # 134-155 is a good metering block to use,...
Holley # 134-155 is a good metering block to use, I have several on the shelf.
The .032" IFR metering block can be made to work just fine.
The white whistle once shortened slightly can be a much...
Forum:
Pontiac - Street
05-09-2023, 04:02 PM
83
6,975
Posted By
1968GTO421
I checked out their web site and the adjustable...
I checked out their web site and the adjustable metering block looks like a great solution to incorperating Tom's advice in the previous post. I need to look at my old Holley and see if this may...
Forum:
Pontiac - Street
03-19-2023, 05:36 PM
83
6,975
Posted By
1968GTO421
My thanks to Chiphead for starting this thread....
My thanks to Chiphead for starting this thread. I'm learning and re-learning alot of good material here.
Forum:
Pontiac - Street
03-13-2023, 02:50 PM
83
6,975
Posted By
Tom Vaught
If you are willing to drill a small hole on each...
If you are willing to drill a small hole on each secondary throttle blade you can almost close the secondary throttle blades. .030" is a good starting size.
Some Holley carb applications already...
Forum:
Pontiac - Street
03-12-2023, 09:30 AM
83
6,975
Posted By
25stevem
13 inches of hot idle vacuum sounds low to me for...
13 inches of hot idle vacuum sounds low to me for that cam and heads with a chamber volume of under 80 CCs , especially if you have a auto trans and that’s out of gear idle vacuum!
The question...
Forum:
Pontiac - Street
02-28-2023, 08:55 PM
35
Good street shocks., 67 A body?
2,831
Posted By
1968GTO421
FWIW After talking with another GTO guy, he...
FWIW After talking with another GTO guy, he recommended Spohn Performance to me as well as UMI. Both are in PA and Spohn manufactures their stuff in the USA.
I used their 926A sway bars with their...
Forum:
Pontiac - Street
02-27-2023, 04:37 PM
35
2,831
Posted By
Schurkey
Spacer or no spacer makes no difference. What...
Spacer or no spacer makes no difference. What matters is ride-height.
The usual problem with jacking-up the back end of an A-body for tire clearance is that it makes the suspension subject to...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
06:58 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
