Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 2
1
2
Showing results 1 to 25 of 34
Search took
0.01
seconds.
Search:
Posts Made By:
70GS455
Forum:
70-73 Firebird & TA TECH
05-03-2024, 09:20 PM
23
Gauge Cluster Restoration
1,467
Posted By
70GS455
My conversion will allow your tach to operate...
My conversion will allow your tach to operate with only one wire and will be compatible with points, HEI, MSD box with the dedicated tach wire, or any points conversion ignition that is not multi...
Forum:
05-01-2024, 09:59 PM
23
1,467
Posted By
70GS455
Depending on whose circuitry is inside the tach,...
Depending on whose circuitry is inside the tach, an HEI will work, it's just the voltage stresses are higher and the circuit components need to be selected to handle it properly. An MSD box is a...
Forum:
Pontiac - Street
04-16-2024, 05:21 PM
55
1000+ cfm from a Qjet
4,016
Posted By
70GS455
Ran across this article from David Vizard's "How to Build Horsepower" Vol 2. They discuss modifications on a Quadrajet to get to 1090 CFM, as measured by a flow bench.
Forum:
Exhaust TECH
03-22-2024, 09:55 PM
8
Turbo muffler internal design
1,539
Posted By
70GS455
There are 2 case sizes for the Dynomax Super...
There are 2 case sizes for the Dynomax Super turbos. The larger case (5.5 x 11") with 3" inlet and outlet do not neck down internally. The smaller case (4.25 x 9.75) do neck down for the 3". I...
Forum:
Pontiac - Race
01-31-2024, 03:50 PM
13
Engine 2 Dyno w Custom 12-1 Crank Trigger, Finally Done Correctly
984
Posted By
70GS455
Looks more like an engine Dyno than a chassis...
Looks more like an engine Dyno than a chassis dyno
Sent from my SM-S901U using Tapatalk
Forum:
Pontiac - Street
11-05-2023, 09:27 PM
12
Yep, another cam degree question
748
Posted By
70GS455
If that's a voodoo grind, I believe they check...
If that's a voodoo grind, I believe they check their advertised duration at some non-standard height. I seem to recall Harold saying something like it had to do with marketing
Sent from my...
Forum:
Pontiac - Street
10-28-2023, 09:01 PM
62
What air cleaner ???
4,659
Posted By
70GS455
I would not recommend using that air cleaner...
I would not recommend using that air cleaner base. We did Dyno testing with one just like that on a QJ and it lost a surprising amount of power
Forum:
Pontiac - Street
09-06-2023, 12:44 PM
80
Coolant ratio
4,598
Posted By
70GS455
With a large enough radiator, or one that is...
With a large enough radiator, or one that is super efficient and has an overabundance of cooling capacity, I beg to differ.
Forum:
Pontiac - Street
06-30-2023, 05:48 PM
121
Comp Cam now a Bullet
4,911
Posted By
70GS455
The "formula" is called "major intensity" ...
Forum:
Pontiac - Street
04-12-2023, 04:12 PM
18
Engine temp -- too high?
1,673
Posted By
70GS455
If you have a 210 deg thermostat then everything...
If you have a 210 deg thermostat then everything is fine. If you have a t stat rated at 160 then there is a cooling capacity issue
Sent from my SM-T817V using Tapatalk
Forum:
Pontiac - Street
03-22-2023, 09:59 PM
26
Vacuum advance
2,352
Posted By
70GS455
You know when you're at WOT the vac advance goes...
You know when you're at WOT the vac advance goes away, leaving you with just mechanical advance. So in that case, it's just like not having it
Forum:
Heating & Cooling TECH
12-13-2022, 06:31 PM
24
Cool weather engine temp
2,762
Posted By
70GS455
Sounds like your thermostat is faulty, staying...
Sounds like your thermostat is faulty, staying partially open when it should be closed while the coolant is under the set point. Not a hard task to replace one but won't really cause any problems,...
Forum:
Pontiac - Street
06-07-2022, 11:02 PM
33
Carter thermoquads (TQ)
3,332
Posted By
70GS455
Low end nanners were not that wonderful. I have...
Low end nanners were not that wonderful. I have not driven it, only dyno time. But idle was the worst of 3 carbs, mid range was poor, and it wouldn't roll into the start of the test (3200 rpm) very...
Forum:
Pontiac - Street
05-05-2022, 05:16 PM
31
The Great Flywheel Weight Debate!
3,556
Posted By
70GS455
It's close enough it should be ok. Where it...
It's close enough it should be ok. Where it matters most is racing at the strip with slicks or drag radials. On the street, it should be fine.
Forum:
Pontiac - Street
05-04-2022, 04:02 PM
31
3,556
Posted By
70GS455
If you decide on an aluminum flywheel, make sure...
If you decide on an aluminum flywheel, make sure you have at least 10:1 SLR (starting line ratio) which is rear gear times first gear ratio
Forum:
Pontiac - Street
03-28-2022, 05:06 PM
27
Rally Gauge Conversion and Gauge Accuracy
3,033
Posted By
70GS455
I repair tachometers and calibrate gauges as a...
I repair tachometers and calibrate gauges as a side. IMO, the best senders I like to use are NAPA for oil pressure and Lectric Limited for water temp. There is a good informational page about senders...
Forum:
Pontiac - Street
03-03-2022, 12:25 PM
4
how to test
649
Posted By
70GS455
Get a large pot of water and heat it on the...
Get a large pot of water and heat it on the stove. Use either a 12v power supply or a battery to power the gauges. Hook up the sender to the gauge, ground both the sender and the gauge to the 12v...
Forum:
Pontiac - Street
02-17-2022, 08:14 PM
34
Engine paint on new parts?
5,605
Posted By
70GS455
Same. Mine looks almost stock, which is the...
Same. Mine looks almost stock, which is the desired effect
Forum:
Pontiac - Street
02-08-2022, 12:04 AM
37
Sooo, who is the go-to q-jet guru these days?
4,841
Posted By
70GS455
I sent mine to Ken at Everyday Performance for a...
I sent mine to Ken at Everyday Performance for a level 2 build. Did 586 hp and 603 ft lbs on my engine. Only 9 hp less than a Holley 950 HP Ultra. Flawless startup, midrange and idle. It was also...
Forum:
08-27-2021, 03:16 PM
7
Now I understand 65 GTO's run compressors full time; anybody try POA Valve "Update"?
1,819
Posted By
70GS455
Correct on the wiring. The superheat im...
The superheat im talking about is the temperature rise across the evaporator, you adjust the TVX for flow to put it in the optimal range for conditions, and to prevent...
Forum:
08-27-2021, 11:47 AM
7
1,819
Posted By
70GS455
Our A6 compressor and specifically the clutch was...
Our A6 compressor and specifically the clutch was never designed to cycle like the modern compressors
Forum:
Interior TECH
08-24-2021, 11:57 AM
30
High bolster seats
5,709
Posted By
70GS455
While not the high bolsters like pictured, i...
While not the high bolsters like pictured, i wanted to use the stock seat covers but added extra side bolster springs. In the pics, the blue tape shows the springs I added, 4 to the upper frame and 4...
Forum:
Pontiac - Street
08-13-2021, 11:31 AM
36
Total mechanical advance question
7,080
Posted By
70GS455
I'm in the camp of the best timing will be what...
I'm in the camp of the best timing will be what the engine wants. We started off on the dyno with the "all in" by 2800 or whatever but quickly found out through testing that this was not optimal. We...
Forum:
07-28-2021, 04:03 PM
22
Thermostats - Rated Temperature and Fully-Open Temperature
13,472
Posted By
70GS455
Actually it does hold up. At that cold of a day,...
Actually it does hold up. At that cold of a day, you have almost infinite cooling capacity. It should be NO different on a hot day if the cooling system is adequate or sufficient. Granted nothing is...
Forum:
07-26-2021, 03:50 PM
22
13,472
Posted By
70GS455
None of that really matters. The tstat rating is...
None of that really matters. The tstat rating is the set-point or regulation point. It is the system operating design point. It is the temperature at which the cooling system water is designed to...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
09:35 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
