Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Showing results 1 to 17 of 17
Search took
0.01
seconds.
Search:
Posts Made By:
zippy
Forum:
Pontiac - Street
05-04-2024, 11:58 AM
20
.005 or .010 shorter cam chain needed?
1,183
Posted By
zippy
had a nasty Hydrolock once, filled bottom end...
had a nasty Hydrolock once, filled bottom end with coolant then split no 7 cyl. Had it sleeved. Then a few years later, Exh lobe on No 5 went flat and basically locked motor with combustion...
Forum:
Pontiac - Street
04-26-2024, 12:26 PM
20
1,183
Posted By
zippy
Well, I just ordered the Rollmaster -.010 from...
Well, I just ordered the Rollmaster -.010 from Butler last night. New stock chain had just under 1/2" slack 1/4" each way. And Crank to Cam CL has been measured to .00675" closer than stock. ...
Forum:
Pontiac - Street
04-05-2024, 09:57 AM
37
Safety warning welding and brake cleaner. Never mix them!
1,796
Posted By
zippy
I only use Acetone for cleaning before I TIG. ...
I only use Acetone for cleaning before I TIG. It's much safer. Plus, all my brake clean is Non Chlorinated. Ya, Chlorinated did clean a bit better, but the risks are not worth it. Phosgene gas...
Forum:
Pontiac - Street
12-16-2022, 02:46 AM
37
PRW 1.5 Roller rocker
2,880
Posted By
zippy
FWIW I have a bare alum set of Scorpion 1.65. No...
FWIW I have a bare alum set of Scorpion 1.65. No annodizing at all. They have been in about 20,000 mi I would est. Comp 995 springs. No issues. Just rebuilt and checked al due to another flat...
Forum:
Pontiac - Street
11-17-2022, 12:21 PM
12
Inspection scope/borescope
1,186
Posted By
zippy
I have a couple USB ones that connect to laptop,...
I have a couple USB ones that connect to laptop, Work awesome. But you need a laptop to get close to what you want to inspect
Forum:
Pontiac - Street
08-13-2022, 12:27 AM
8
Found the problem
1,118
Posted By
zippy
Smooth the sharpness down on the piston and head...
Smooth the sharpness down on the piston and head and she will be OK!. Sharp edged create hot spots and unless you running the jagged edge of compression, Which I think unlikely. a smooth over to...
Forum:
Pontiac - Street
08-11-2022, 11:16 AM
47
Timing chain replacement with new cam.
4,190
Posted By
zippy
You need to find #1 TDC on Compression stroke. ...
You need to find #1 TDC on Compression stroke. Means, both Intake and Exh valve closed and piston at TDC. If your balancer is wrong to the timing cover marks, you will need a degree wheel and a...
Forum:
Pontiac - Street
06-30-2022, 09:51 PM
11
2nd Gen Side Glass Adjustment
735
Posted By
zippy
Here ya go!! I still have it shared on my old...
Here ya go!! I still have it shared on my old Powdercoating website.
https://www.banditpowdercoat.com/Downloads/stuff/GM_Window_Adjustment_Guide.pdf
Forum:
Pontiac - Street
06-30-2022, 09:48 PM
9
Llifters, again. sigh.
1,204
Posted By
zippy
I would take that lifter out, dissasemble and...
I would take that lifter out, dissasemble and clean inside parts. Could just be varnished up. Yes, the leak down is mostly through parts tolerance and oil up the pushrod. Also check your pushrod...
Forum:
Pontiac - Street
06-29-2022, 11:27 PM
29
How do they get blocks this clean!
3,202
Posted By
zippy
Ummm OUCH!! and Ya, point blank. Kinda says...
Ummm OUCH!! and Ya, point blank. Kinda says whats gona happen
Forum:
Pontiac - Street
06-29-2022, 11:21 PM
29
3,202
Posted By
zippy
Seen the new Laser rust cleaning??? Prob not...
Seen the new Laser rust cleaning??? Prob not used on blocks, most are bathed, then put into a shot blasting cabinet with steel BB's. But man, the new Lase tech is wicked!
Forum:
Pontiac - Street
06-23-2022, 11:09 AM
17
I have posted many threads over the years
2,522
Posted By
zippy
Being an industrial electrician, I know all to...
Being an industrial electrician, I know all to well the raw torque of electric motors. Especially at 100% slip speed. (0 rotor speed, or right at start, for those that don't know) Elec motors can...
Forum:
Pontiac - Street
06-12-2022, 10:16 AM
816
Question about 041 Cam
67,708
Posted By
zippy
For giggles. Here's my block, next to one of my...
For giggles. Here's my block, next to one of my planes. Stupid phone tils sideways when uploading here it seems
Forum:
Pontiac - Street
04-16-2022, 10:42 AM
50
Scat crank thrust too small
7,750
Posted By
zippy
Ya, while that would probably work fine in...
Ya, while that would probably work fine in lubricating steel on steel thrust. When I paid for a properly built 455 bottom end and forged crank, I want a PROPERLY built one. Not one that I will have...
Forum:
Pontiac - Street
04-06-2022, 01:31 PM
50
7,750
Posted By
zippy
So latest update. I take my crank and the...
So latest update. I take my crank and the bearings to the shop who originally did the bottom end. Told him, and showed him that the counterweights will have to be shaved down too. The crank was...
Forum:
Pontiac - Street
03-17-2022, 09:45 PM
50
7,750
Posted By
zippy
For the record, I will be doing my own assembly...
For the record, I will be doing my own assembly and measuring everything. This has been the first time I ever had someone assemble a bottom end for me. Prob 8-10 engines in my life with no...
Forum:
Pontiac - Street
03-14-2022, 07:29 PM
6
Melling SPC-8 spring pressure?
809
Posted By
zippy
Like what is safe open pressure for a Street...
Like what is safe open pressure for a Street warrior type engine on a flat tappet cam?
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
10:51 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
