Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 3
1
2
3
Showing results 1 to 25 of 56
Search took
0.01
seconds.
Search:
Posts Made By:
n20ta2
Forum:
Ames Customer Satisfaction Forum
07-06-2023, 08:44 PM
12
Dissapointed
1,616
Posted By
n20ta2
Thanks for the recommendation! I coincidentally...
Thanks for the recommendation! I coincidentally had called them and they are going to help me out.
Forum:
07-06-2023, 12:17 PM
12
Dissapointed
1,616
Posted By
n20ta2
Dissapointed
I placed an order for black loop carpeting dor my 69 gto along with some other items 3 weeks ago and understood at that time that the carpet would be drop shipped and I wouldn't see it for a couple...
Forum:
Pontiac - Street
07-05-2023, 09:11 PM
22
1969 gto hiports hit wiper motor
1,031
Posted By
n20ta2
I'm running tall fabricated valve covers and that...
I'm running tall fabricated valve covers and that might be half my issue.
Forum:
Pontiac - Street
07-05-2023, 09:10 PM
22
1,031
Posted By
n20ta2
I used the kauffman crossover. I didn't like the...
I used the kauffman crossover. I didn't like the idea of plugging it.
Forum:
The Body Shop TECH
05-24-2023, 11:55 AM
7
Are there any new products for Endura Bumper refinish?
1,013
Posted By
n20ta2
Nothing I'm aware of that I would be willing to...
Nothing I'm aware of that I would be willing to try. The 3m flexible parts repair works excellent and sands easily. As far as epoxy primers I'm sure there are some others out there that would work...
Forum:
68-69 GTO Tempest & LeMans TECH
02-28-2023, 09:50 PM
3
Help with 69 parking lamp socket
546
Posted By
n20ta2
Yes! Just added to my cart!
Forum:
Pontiac - Street
12-15-2022, 09:12 AM
37
PRW 1.5 Roller rocker
2,830
Posted By
n20ta2
Probably good for your build but I cant run...
Probably good for your build but I cant run stamped steel rockers with my spring pressure.
Forum:
Pontiac - Street
12-06-2022, 08:09 PM
37
2,830
Posted By
n20ta2
Was thinking the same thing, probably wont ever...
Was thinking the same thing, probably wont ever need another set.
Forum:
Pontiac - Street
12-06-2022, 04:45 PM
37
2,830
Posted By
n20ta2
Im going to use either the crane golds or I might...
Im going to use either the crane golds or I might bite the bullet and go with the crower enduro. There over 800 for all 16 though.
Forum:
Pontiac - Street
12-06-2022, 08:48 AM
37
2,830
Posted By
n20ta2
Thats exactly the experience im leaning on,...
Thats exactly the experience im leaning on, thanks for reposting it. Im running 1.65 on a fairly rowdy hydraulic roller and highports. I'm afraid its a recipe for disaster.
Forum:
Pontiac - Street
12-05-2022, 01:02 PM
23
HP 950 primary vs secondary throttle plate idle setting
1,218
Posted By
n20ta2
Good info thanks a bunch! Fst was no help on the...
Good info thanks a bunch! Fst was no help on the phone with my situation
Forum:
Pontiac - Street
12-05-2022, 09:07 AM
37
2,830
Posted By
n20ta2
Im with you on this, Butler reccomended the prw...
Im with you on this, Butler reccomended the prw ss rockers but im not happy about using thwm long term after hearing a few past stories. Probably replacing mine this spring.
Forum:
11-26-2022, 01:47 AM
34
Mouse proofing the 68 A-Body ??
2,673
Posted By
n20ta2
Yeah Its a tight fit between the frame and that...
Yeah Its a tight fit between the frame and that last hole. Probably could cut a piece of sheet metal big enough to cover it and wedge a wood shim in there to hold it over the hole for the winter. I...
Forum:
11-25-2022, 09:44 PM
34
2,673
Posted By
n20ta2
When I started restoring my 69 it had a ton of...
When I started restoring my 69 it had a ton of mouse nests and I was able to trace all the entry points. If all your body plugs are in place including the ones in the trunk extensions then there...
Forum:
Pontiac - Street
10-01-2022, 01:34 PM
63
Fresh 461 leaking coolant
4,241
Posted By
n20ta2
Got it out! Wow really? Im impressed then!...
Got it out!
Wow really? Im impressed then! both plugs were bad, 3 scores about 1/16 inch deep on each plug. If You think it would have fixed it I may try it next time
Forum:
Pontiac - Street
10-01-2022, 01:19 PM
63
4,241
Posted By
n20ta2
Omg I should but a lottery ticket! Used s small...
Omg I should but a lottery ticket! Used s small pice of steel rod with a hook bent into it and managed to hood it between the plug and a bit of sealant that formed a hoop and got it out.
Forum:
Pontiac - Street
09-28-2022, 06:27 PM
63
4,241
Posted By
n20ta2
Yeah its the freeze plugs. I was able to get an...
Yeah its the freeze plugs. I was able to get an inspection mirror behind the torque converter and could clearly see antifreeze running from a spot where the edge of the plug meets the block. Crap.
Forum:
Pontiac - Street
09-23-2022, 10:56 PM
22
No spark msd ignition
1,173
Posted By
n20ta2
Accessory wire in my painless wiring harness. I...
Accessory wire in my painless wiring harness. I just double checked it and its 12 v keyed and drops to 0v cranking. Thats probably my issue. I will try hooking the signal wire to the bat and see if I...
Forum:
Pontiac - Street
07-12-2022, 02:41 PM
7
Pypes 3" A body exhaust fitment issues
1,504
Posted By
n20ta2
Im welding the pipes behind the muffler and using...
Im welding the pipes behind the muffler and using stainless band clamps everywhere else in case I have to remove the x pipe for trans access
Forum:
The Body Shop TECH
06-19-2022, 07:46 AM
22
Front Clip Shimming
2,525
Posted By
n20ta2
I would think that it would only be off on one...
I would think that it would only be off on one side if the one horn was bent. If you have to slide the bumper all the way left or right and it still won't line up you more then likely need to shift...
Forum:
The Body Shop TECH
06-18-2022, 09:08 AM
22
Front Clip Shimming
2,525
Posted By
n20ta2
Might have to notch the bumper brackets to get...
Might have to notch the bumper brackets to get them lower if it doesn't have enough travel
Forum:
The Body Shop TECH
06-14-2022, 12:06 PM
22
Front Clip Shimming
2,525
Posted By
n20ta2
If your front horn is bent you have no choice but...
If your front horn is bent you have no choice but to shim it, I used a repop core support as well but when I measured from the mounting point to the top of the core it was the same. Mine fortunately...
Forum:
The Body Shop TECH
06-04-2022, 09:49 PM
8
Help identifying primer sealer used on my '67 GTO project
1,344
Posted By
n20ta2
If it's sat in primer since 99 or 2000 I would...
If it's sat in primer since 99 or 2000 I would definitely strip it back down. Primer is porous and if left for an extended period of time will let moisture through and you most likely will have...
Forum:
The Body Shop TECH
05-22-2022, 06:30 PM
4
Any Dampening Foam pointers?
1,167
Posted By
n20ta2
I used the SEM brand it looks more like factory,...
I used the SEM brand it looks more like factory, but it did distort the quarter a tiny tiny bit. I ended up blocking it again and spraying another coat of epoxy and that fixed it., i forgot to do it...
Forum:
The Body Shop TECH
04-16-2022, 09:41 PM
23
Endura primer
3,130
Posted By
n20ta2
I'm not carrying the spi flag at all, I have used...
I'm not carrying the spi flag at all, I have used all of the mentioned epoxy primers over the years and still do. The only reason I used the spi on my 69 front bumper is it was suggested by user...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
01:24 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
