Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 2
1
2
Showing results 1 to 25 of 28
Search took
0.02
seconds.
Search:
Posts Made By:
Billz428
Forum:
Pontiac - Street
06-01-2021, 10:44 AM
16
041 Roller Cam
3,040
Posted By
i82much
a smidge bigger and you are basically old...
a smidge bigger and you are basically old faithful, a smidge smaller and you have stump puller. my guess is that butler is trying to fit into a narrow window here with a marketing idea that has a...
Forum:
Pontiac - Street
05-23-2021, 01:20 PM
18
Crane 296 B
2,450
Posted By
Formulajones
Hard to say. If they peak around .600 lift...
Hard to say. If they peak around .600 lift then you won't be taking full advantage. With this cam only having about .530" lift with a 1.65 rocker it would work pretty nice on heads that peak in...
Forum:
Pontiac - Street
05-22-2021, 07:26 AM
23
Loose Timing Chain
7,182
Posted By
steve25
The only time I have ever seen one so loose was...
The only time I have ever seen one so loose was on a Mopar 318 I had when it failed and jumped, time and fortunately did so on a restart and did not bend any valves!
Did you soak that chain in a...
Forum:
Pontiac - Street
05-22-2021, 12:24 AM
18
Crane 296 B
2,450
Posted By
NeighborsComplaint
You may find that Lunati a little tame in a 455...
You may find that Lunati a little tame in a 455 compared to the Crane 296B but it will run fine.
Forum:
Pontiac - Street
05-15-2021, 01:04 PM
28
Old School 445 Build
6,799
Posted By
steve25
Sorry, but I don’t consider a 4.56 rear geared...
Sorry, but I don’t consider a 4.56 rear geared 455 any where near a street car, and even back in 1978 it was not all that easy to turn up a set of 455 HO round port heads unless you already had such...
Forum:
Pontiac - Street
05-08-2021, 03:24 PM
19
Swap cam while motor is In ?
2,886
Posted By
steve25
Note that as soon as you get the timing cover off...
Note that as soon as you get the timing cover off if the 2 lower bolt hole sleeves are not in the cover, but still on the face of the block do as posted above, pack the open nose of the oil pan until...
Forum:
Pontiac - Street
05-07-2021, 10:31 PM
19
2,886
Posted By
PAUL K
Yes, the hood latch support bar will need to be...
Yes, the hood latch support bar will need to be loosened and pushed out of the way. If the car has AC the condenser will need to be moved around but shouldn't have to be disconnected.
Forum:
Pontiac - Street
05-06-2021, 12:12 PM
14
1/2” fuel line
1,960
Posted By
RocktimusPryme
I bought an 1/2 stainless line for my first gen. ...
My one note would be to be prepared for nasty shipping costs. I think shipping was basically the same cost as the line in my case.
Forum:
Pontiac - Street
04-23-2021, 09:45 PM
27
455HO cam choice
4,901
Posted By
Steve C.
A fwiw tid bit, the 'Stump Puller' is nothing...
A fwiw tid bit, the 'Stump Puller' is nothing more than Comp lobes 3111B & 3122B ordered with a 112 lobe separation and 5 degrees advance ground into the cam. Order it thru any Comp dealer. The...
Forum:
Pontiac - Street
04-18-2021, 10:52 AM
10
Looking for cam swap suggestions
2,023
Posted By
steve25
Ok, so let’s nail down some added and needed...
Ok, so let’s nail down some added and needed details here!
Can we assume your staying with a 400 cid motor and just going to bore it .030” over, if so then those 6X-4 heads will give you a...
Forum:
Pontiac - Street
04-08-2021, 01:33 PM
73
Oil Starvation W/Canton Pan
10,684
Posted By
HWYSTR455
Just to comment, although Canton lists the pan as...
Just to comment, although Canton lists the pan as '6qt', that is the pan itself, so it should be 6+1 (for filter to fill). In some cases, another qt may be desired, so you can go 8 total, plus the...
Forum:
Pontiac - Street
04-08-2021, 12:36 PM
73
10,684
Posted By
JLMounce
Every bit of research I've done personally points...
Every bit of research I've done personally points to the 6 qt pan simply not being enough volume for hardcore road race stuff, especially on anything close to an R compound tire. Baffles and trap...
Forum:
Pontiac - Street
02-23-2019, 05:33 AM
27
Edelbrock Cylinder Heads OK?
4,396
Posted By
Ivo
Thanks for answers, in 2-3 weeks i will update my...
Thanks for answers, in 2-3 weeks i will update my 455 4XHeads engine with that package ...
Forum:
Pontiac - Street
07-25-2014, 06:01 PM
18
Changed my timing chain today and wow.
976
Posted By
Tom Vaught
You will be fine. The chain will stretch a slight...
You will be fine. The chain will stretch a slight bit. This is the street section and you are not after maximum HP, so if the chain retards 1 degree (when broken in) it is no big deal really.
The...
Forum:
Pontiac - Street
12-29-2013, 08:54 PM
46
Pulled the 474 Cam swap and more
2,506
Posted By
BARRACUDA1968
That's funny that you just mentioned "old...
That's funny that you just mentioned "old faithful" and Sd Performance. I was just on their site.:)
I have read about that cam on several threads here. Didn't realize it was a custom grind by a...
Forum:
Pontiac - Street
12-04-2013, 12:11 PM
52
pics of 3" exhaust on a 2nd gen bird
2,388
Posted By
twov8sandat4
3" Pypes x-pipe with Race Pro mufflers and 3"...
3" Pypes x-pipe with Race Pro mufflers and 3" tips on my 74. It does tuck up very nicely into the body.
Note: the left tailpipe was bent wrong, so we had to use an offset exit muffler on the...
Forum:
Pontiac - Street
12-01-2013, 10:23 AM
35
looking for a little expert advice for engine upgrade...
1,792
Posted By
Cliff R
As far as power with manifolds compared to...
As far as power with manifolds compared to headers, we've seen over 40hp difference back to back on the dyno with two different headers, so it's all about how well they are made, and the engine...
Forum:
Pontiac - Street
11-27-2013, 08:30 AM
11
Engine Build Comments Needed 475hp or Bust
1,011
Posted By
Cliff R
We built and dyno tested the 455 for KRE's...
We built and dyno tested the 455 for KRE's "500hp" crate engine years before the KRE aluminum "D" port heads came out. We used out of the box Edelbrock aluminum round port heads, Crower 60919 cam,...
Forum:
Pontiac - Street
11-26-2013, 12:26 AM
126
What grade of fuel? Newly rebuilt 455, 9.5:1 compression - Specs inside
8,374
Posted By
KEN CROCIE
CliffR #50 post. I've been giving that speech to...
CliffR #50 post. I've been giving that speech to customers for years. Good job.
General Z: Install the 6H heads and enjoy life once again. Dont spend money on another intake--it just won't make...
Forum:
Pontiac - Street
11-24-2013, 10:04 AM
126
8,374
Posted By
Cliff R
"For me, horsepower on this car is the LEAST...
"For me, horsepower on this car is the LEAST concern. I don't care if I leave 100 hp on the table."
The TQ/HP will be there with the right cam, and the engine will run better everyplace, cooler,...
Forum:
Pontiac - Street
11-23-2013, 07:07 AM
126
8,374
Posted By
Cliff R
I guess that I'll have to be the bearer of bad...
I guess that I'll have to be the bearer of bad news here, WRONG cam choice. Not sure who or how you got that little cam combo'd up with a 455 engine at a SCR of 9.5 to 1, but it is not only the...
Forum:
Pontiac - Street
11-21-2013, 06:52 AM
17
Crower 60243 with 1.65 rockers VS. Crower 60919
3,331
Posted By
Cliff R
Steve, here's my take on the deal. The 455 is a...
Steve, here's my take on the deal. The 455 is a HUGE engine. It is not a very efficient engine being undersquare and swinging pretty heavy parts. Piston speed is also pretty high in them.
By...
Forum:
Pontiac - Street
11-21-2013, 12:29 AM
17
3,331
Posted By
Steve Barcak
Thank you for the reply. I appreciate your...
Thank you for the reply. I appreciate your comparisons with cam and comp ratio. However, with either cam, you would be better with more compression ( up to your octane limit ) correct?
You also...
Forum:
Pontiac - Street
11-20-2013, 10:24 AM
17
3,331
Posted By
Cliff R
420-430hp, 500 plus ft lbs torque. Peak HP...
420-430hp, 500 plus ft lbs torque. Peak HP around 5000-5200rpm's. With the 60919 cam, peak HP will be 5400-5600rpms, if you use high ratio rockers on it.
When we dyno'd my last 455 with unported...
Forum:
Pontiac - Street
11-14-2013, 07:51 PM
52
2,388
Posted By
ta man
You can always order 3 inch Pypes X crossover...
You can always order 3 inch Pypes X crossover ,use cone reducers into good flowing 2.5 mufflers (I use Ultraflows)and order 2.5 flowmaster tailpipes...
I've ran almost 119mph with a similar...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
12:39 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
