Forum: Garage Sale
09-17-2021, 06:47 PM
Forum: Pontiac - Street
07-28-2021, 03:22 PM
Forum: THE LOBBY
05-31-2021, 10:10 AM
I took these a week ago at a "cottage" in...
I took these a week ago at a "cottage" in Earleville, MD. My daughter rented it for a family get together. I would sit outside and watch the bald eagles. This is one of the pictures that I got of...
Forum: THE LOBBY
05-02-2021, 09:32 PM
Big Ugly.
Big Ugly.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=565830&stc=1&d=1620005453
06-10-2020, 08:08 PM
Bringing this one back for more info. The Ford...
Bringing this one back for more info. The Ford F-250 pulley that is referenced above should only be considered for use with the shorter water pump snout in 1968 / 69. The correct Ford number for the...
12-17-2019, 04:54 PM
Not sure how pertinent this to your setup since...
Not sure how pertinent this to your setup since you’re running a 455....I’m running the Voodoo 703 in 400 with #15 small chamber, small valve heads. I had the rocker studs changed for screw in, and...
12-17-2019, 03:09 PM
Concur. Whatever cam you think you need in a...
Concur. Whatever cam you think you need in a 455, you can probably go bigger.
After about a week on my 462 I realized I under-cammed it and I've got a stick in there that's just a bit shy of the...
12-17-2019, 02:51 PM
12-17-2019, 10:55 AM
12-06-2019, 09:20 AM
Dynoed my 389, very pleased.
Nothing spectacular, but a very nice street motor that will be a lot of fun to drive. 1965 389 with 76 heads built and ported by SD Performance. Crossovers filled, threaded rocker studs, hardened...
Forum: Members Helping Members
02-10-2014, 03:35 PM
Even with no CAT, 1200ppm HC is way too...
Even with no CAT, 1200ppm HC is way too high....my '67 GTO puts out less than 200ppm HC. High HC is usually caused by a misfire or a lean condition. High CO is caused by a rich condition. Check...
01-16-2014, 03:06 PM
Having lived through a transmission order from...
Having lived through a transmission order from Keisler, I wouldn't do it again. Besides the endless line of crap concerning why it was late, once I got it they did their best to make my GTO into a...
12-30-2013, 03:09 PM
12-17-2013, 11:22 PM
The nightmare wont end.Got the pass side...
The nightmare wont end.Got the pass side fixed.Put the bellhousing on and the drivers side hits.I said WTF?Wait,the deck is a inch shorter!It moves the headers closer to the block,starter and bell...
12-13-2013, 11:41 PM
12-11-2013, 10:44 AM
12-11-2013, 10:42 AM
12-11-2013, 07:23 AM
12-10-2013, 09:37 PM
Forum: 66-67 GTO Tempest & LeMans TECH
12-08-2013, 12:49 PM
The windshield cleaner pump?
Correct I...
Correct I pushed in the knob to clean my windshield and the bugger just kept pumping and the wipers kept flapping.
My wife laughed her a$$ of while scrabbled to...
Forum: The Body Shop TECH
12-04-2013, 05:48 PM
11-15-2013, 03:02 AM
Im in the process of going with an 18" myself....
Im in the process of going with an 18" myself. From all of my resarch on this topic ive found that no one makes real performance tires in 15". They are also getting pricey. 15" tires are just as...
Forum: THE LOBBY
11-14-2013, 08:01 PM
Forum: 67-79 Big Pontiac TECH
11-10-2013, 06:25 PM
Forum: THE LOBBY
11-10-2013, 01:41 AM
Automatic or 4 speed? Whats your pleasure?
I may have the chance to buy a super nice car (Im going to leave the car unknown because of who owns it) but its a 4 speed. Ive owned modern day stick cars (many of them) but never one from the glory...
