Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 4
1
2
3
Last
Showing results 1 to 25 of 76
Search took
0.02
seconds.
Search:
Posts Made By:
Gary H
Forum:
Pontiac - Street
03-10-2024, 04:39 PM
33
CAM CHOICE
1,173
Posted By
Gary H
I have a shop here in Jacksonville, Florida and...
I have a shop here in Jacksonville, Florida and do nothing but Pontiac's. We've built over 150 Pontiac engines. I think the combination you described is pretty good all the way around. Your vacuum...
Forum:
Pontiac - Street
01-26-2024, 12:44 PM
9
400 small register crank strength
2,168
Posted By
Gary H
Thanks Paul! I thought I had heard that a while...
Thanks Paul! I thought I had heard that a while back too. I'm going to use it.
Forum:
Pontiac - Street
01-26-2024, 09:27 AM
46
Who has successfully installed a hydraulic flat tappet cam recently?
3,491
Posted By
Gary H
I've built about 10 flat hydraulic flat tappet...
I've built about 10 flat hydraulic flat tappet lifter Pontiac engines over the last 2 years. No issues on them. I only use Hy-lift Johnson lifters though.
Forum:
Pontiac - Street
12-08-2023, 06:44 PM
65
Too big main clearance after alignhone
6,475
Posted By
Gary H
That's a BIG variance from main to main. If...
That's a BIG variance from main to main. If those numbers are accurate, I would take it back to the machine shop and see what's up. Just a FYI, Clevite bearings generally will measure thicker than...
Forum:
Pontiac - Street
12-06-2023, 04:18 PM
25
Fuel delivery issue
1,090
Posted By
Gary H
If the pump has a return line from the pump to...
If the pump has a return line from the pump to the tank that was still hooked up during the 15 minutes of run time, then most of the fuel went back to the tank through the return.
Forum:
Pontiac - Street
11-27-2023, 02:43 PM
24
engine surging
1,377
Posted By
Gary H
What power piston spring did you put in the carb?...
What power piston spring did you put in the carb? The ram air IV cam doesn't create much vacuum in a 400 and the wrong spring may be causing the issue. You may also want to check and make sure you...
Forum:
Pontiac - Street
11-27-2023, 09:46 AM
5
No spark with FiTECH
663
Posted By
Gary H
Check and see if the handheld is showing any RPM...
Check and see if the handheld is showing any RPM while trying to crank the engine.
Forum:
Pontiac - Race
11-15-2023, 03:01 PM
19
Pcv grommet?
1,073
Posted By
Gary H
If the valley pan you have is the single piece...
If the valley pan you have is the single piece one, it is very prone to suck oil through the PCV valve. I never use those. I'd buy a reproduction piece pan and use that.
Forum:
Pontiac - Street
09-07-2023, 07:18 PM
41
Rod Clearance - Tracking down .005
1,794
Posted By
Gary H
.003 is a little on the loose side for a strictly...
.003 is a little on the loose side for a strictly street engine IMO. I'd try a different brand bearing to see if it's a little thicker to get you closer to .002 or .0025. In my experience, Clevite...
Forum:
Pontiac - Street
06-08-2023, 07:12 PM
11
Oil support rail issue
610
Posted By
Gary H
Sure sounds like it. I'd measure the grove and...
Sure sounds like it. I'd measure the grove and then contact Ross.
Forum:
Pontiac - Street
05-30-2023, 07:48 AM
21
Oil pan gasket
1,410
Posted By
Gary H
X2 on the above. I always use the cork seal on...
X2 on the above. I always use the cork seal on the seal with the tabs on it. Had much better results over the years with it.
Forum:
Pontiac - Street
05-29-2023, 12:11 PM
22
455 identification.?
1,433
Posted By
Gary H
No, It's the same identical casting as any other...
No, It's the same identical casting as any other block that year. Pontiac used the same casting number for all 71' - 74' 455 blocks except the SD blocks. The 73' - 74' 455 SD blocks had multiple...
Forum:
Pontiac - Street
04-08-2023, 08:25 AM
174
Molnar rods and cranks
12,527
Posted By
Gary H
So far, the maximum has been a 875 Hp pump gas...
So far, the maximum has been a 875 Hp pump gas engine. I'm currently building an all aluminum engine that has dual Torquestorms on it that should hit 1100 HP. Using Molnar crank and power adder rods
Forum:
Pontiac - Street
04-07-2023, 07:32 PM
174
12,527
Posted By
Gary H
I do, and have, used Molnar rods and cranks in...
I do, and have, used Molnar rods and cranks in most of the builds I do for customers. As several have mentioned previously, the rods and cranks are dead on spec wise. I pay a little more up front...
Forum:
67-69 Firebird TECH
03-12-2023, 05:30 PM
4,159
eBay sightings
669,705
Posted By
Gary H
Bought this car.
Because it was listed on this thread I recently bought this 72' Lemans GT. Amazingly solid southern California car with original paint. Thank you for posting these cars!
Forum:
Pontiac - Street
02-17-2023, 10:06 PM
16
Hydraulic roller cam cores
1,168
Posted By
Gary H
OK, I got a hydraulic roller from Mark at Luhn...
OK, I got a hydraulic roller from Mark at Luhn Performance. He had one in stock that was pretty much the specs I was looking for. Also ordered his oil pump for the engine as well.
Forum:
Pontiac - Street
02-14-2023, 08:09 PM
59
Pontiac hardened valve seat issues
4,927
Posted By
Gary H
I've had three different Pontiac engines in my...
I've had three different Pontiac engines in my shop that had bad recessed exhaust valves. Two engines had 6X heads on them, and other was a mid 60's head. One head had two exhaust valves sunk so...
Forum:
Pontiac - Street
02-05-2023, 05:18 PM
9
JPR Timing Sets
1,091
Posted By
Gary H
Cloyes only for me. And I absolutely will not...
Cloyes only for me. And I absolutely will not use any RollMaster sets. I've had several in here that were off on sprocket inside dimensions and also when degreeing them in.
Forum:
Pontiac - Race
01-31-2023, 07:15 PM
21
My 66 ready to go!
2,520
Posted By
Gary H
I run a 33" tall tire and 4:33 gears. At 154 MPH...
I run a 33" tall tire and 4:33 gears. At 154 MPH I'm at around 7700 RPM's. Partially depends on how tight your convertor is. I don't think a little less gear will hurt you as light as your car is.
Forum:
Pontiac - Race
01-30-2023, 10:02 AM
21
My 66 ready to go!
2,520
Posted By
Gary H
I love the look and finish on your car! Just...
I love the look and finish on your car! Just curious on what tire size you have on it. With a 4:56 gear you may be turning A LOT of rpm's at the big end especially if you think it's going to run...
Forum:
Pontiac - Street
01-03-2023, 07:25 PM
18
Factory 455 Crank Anomaly
1,929
Posted By
Gary H
I recently disassembled a 455 engine that had been installed in a 79' Trans Am by a previous owner. The engine ran great for what it was; 455 with 6X heads, decent camshaft, Holley, etc.. At the...
Forum:
Pontiac - Race
12-31-2022, 05:44 PM
47
REALLY FAST CARS Post up your Opinions Examples
5,855
Posted By
Gary H
Picking up .12 ET, and 3.5 MPH with the...
Picking up .12 ET, and 3.5 MPH with the transmission change is incredible in my mind, especially at that fast of a ET and the toughness of the N.A. class you run in. I'm really surprised. ...
Forum:
Pontiac - Race
12-27-2022, 09:52 AM
47
5,855
Posted By
Gary H
Interesting Paul. I didn't know that he went the...
Interesting Paul. I didn't know that he went the manual transmission route. Do you know how much it picked up?
Forum:
Pontiac - Race
11-16-2022, 08:46 AM
77
Just my .02
7,688
Posted By
Gary H
I'm with Paul on this one. I don't mind a little...
I'm with Paul on this one. I don't mind a little back and forth regarding their opinion on what works or not. But some people go nuclear over every thread they're on. And then there's a certain...
Forum:
69-71 Judges only TECH
11-14-2022, 09:12 AM
14
Mecum Kissimmee
3,203
Posted By
Gary H
That's a high dollar collection! I'd love to...
That's a high dollar collection! I'd love to have any of them, but the 70' black Judge would be my first choice.
Page 1 of 4
1
2
3
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
11:04 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
