Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Showing results 1 to 22 of 22
Search took
0.15
seconds.
Search:
Posts Made By:
STEELCITYFIREBIRD
Forum:
Pontiac - Street
08-11-2022, 12:54 AM
61
Engine stalls when hot...fuel related
6,607
Posted By
STEELCITYFIREBIRD
From experience, a quick sniff of the exhaust...
From experience, a quick sniff of the exhaust when the no start occurs….
>If the exhaust while cranking smells of raw fuel it’s it’s an ignition problem
>If it doesn’t smell of raw fuel it’s...
Forum:
Pontiac - Street
01-10-2021, 02:50 PM
13
Bearing Race Question
1,409
Posted By
STEELCITYFIREBIRD
My opinion yes. Yet Another Excellent...
My opinion yes.
Yet Another Excellent explanation, as usual, Mgarblic!
Shame Timken is sourcing offshore, I have been out of the automotive parts/repair business a long time, use to be a...
Forum:
Pontiac - Street
01-10-2021, 12:47 PM
13
1,409
Posted By
STEELCITYFIREBIRD
https://shop.advanceautoparts.com/p/performance-to...
https://shop.advanceautoparts.com/p/performance-tool-7-pc-bearing-race-and-seal-dr-set-w83020/11931888-p?product_channel=local&store=5003&adtype=pla&product_channel=local&store_code=5003&gclid=EAIaIQo...
Forum:
Pontiac - Street
01-09-2021, 11:08 PM
13
1,409
Posted By
STEELCITYFIREBIRD
🤙🏼 If your not comfortable changing them, your...
If your not comfortable changing them, your better off using the ones already installed, considering the miles your likely to put on the vehicle.
Forum:
Pontiac - Street
01-09-2021, 07:22 PM
13
1,409
Posted By
STEELCITYFIREBIRD
I would use the Timken races. I also would...
I also would recommend replacing the brake hose/s you clamped with vice grips!
:cool:
Forum:
Pontiac - Street
09-17-2020, 12:50 PM
14
Low mileage '84 T/A , in storage and not run since 1996 ADVICE
1,885
Posted By
STEELCITYFIREBIRD
The pics are really bad, it's an estate auction,...
The pics are really bad, it's an estate auction, goes to high bid. Has 1997 State inspection sticker on it! And I see yellow ziebart plugs in door jambs..I think?
Hoping to check it out in the...
Forum:
Pontiac - Street
07-23-2020, 04:17 PM
38
How much coolant to drain for timing cover work
4,808
Posted By
STEELCITYFIREBIRD
If your in there, I'd have a timing chain set on...
If your in there, I'd have a timing chain set on hand....just in case.
Also a good opportunity to check and set the water pump to separator plate clearance.
In for a pound and a half.
Forum:
Pontiac - Street
06-02-2020, 05:22 PM
13
Rocker Studs too long
2,796
Posted By
STEELCITYFIREBIRD
Just thinking out loud... Do you have the guide...
Do you have the guide plates on?
Perhaps you need different length pushrods if geometry is not good?
Personally, if all is good I would shorten the stud or replace with...
Forum:
Pontiac - Street
05-15-2020, 07:51 AM
3
8518pt reuseable?
1,129
Posted By
STEELCITYFIREBIRD
With how cheap a Full engine gasket set is...
With how cheap a Full engine gasket set is ..including those head gaskets, I myself wouldn't even consider it. Ain't got time for a recall.
https://www.summitracing.com/parts/fel-260-1025
Forum:
Pontiac - Street
04-09-2020, 11:56 AM
37
What's the difference between VMAX and VPRO Rhoads?
5,051
Posted By
STEELCITYFIREBIRD
:thanx:;)
:thanx:;)
Forum:
Pontiac - Street
04-04-2020, 10:24 PM
41
Dead or Dying Optima?
8,371
Posted By
STEELCITYFIREBIRD
[/B] Possibly a poor connection from your...
[/B]
Possibly a poor connection from your jumper cables to terminals,
or possibly your cars battery cable connections need cleaned and/or tightened.
You were transmitting power thru your...
Forum:
Pontiac - Street
04-01-2020, 12:01 PM
41
8,371
Posted By
STEELCITYFIREBIRD
RIP Optima!;) The 12.6 was a surface charge, a...
RIP Optima!;)
The 12.6 was a surface charge, a short run of the headlights will likely drop your static voltage too.
:cool:
Forum:
Pontiac - Street
04-01-2020, 08:11 AM
41
8,371
Posted By
STEELCITYFIREBIRD
Voltage drop tests will give you an accurate...
Voltage drop tests will give you an accurate diagnosis.
Check terminal post, then cable lug to pinpoint a bad connection.
https://www.youtube.com/watch?v=XhRPLgH6uZg
If your going to jump...
Forum:
Pontiac - Street
03-31-2020, 08:09 PM
41
8,371
Posted By
STEELCITYFIREBIRD
Put a voltmeter on it, like Ted Sed! Also agree...
Also agree with Paul K, a bad battery is not usually intermittent
Static Voltage ~12.6 fully charged battery and voltage drop for below 10.2, all good...
Forum:
Pontiac - Street
03-19-2020, 12:10 PM
24
New Ignition Points Oxidized
2,288
Posted By
STEELCITYFIREBIRD
Dressing points will get you home! If you used...
If you used a feeler gauge to baseline or if you must, set your points, you better clean the likely oil off them for longevity in service. The corner or a business...
Forum:
Pontiac - Street
02-19-2020, 12:48 AM
16
Distributor for MSD6AL trigger
1,749
Posted By
STEELCITYFIREBIRD
I’ve used a HEI, no problems. ...Change out...
I’ve used a HEI, no problems. ...Change out carbon button in cap to low?(IIRC) resistance unit.
You can easily put the module back in should you cook the MSD box., even roadside.
MSD makes a simple...
Forum:
Pontiac - Street
05-24-2019, 02:27 PM
39
60 vs 80 psi oil pump
5,191
Posted By
STEELCITYFIREBIRD
A gear pump is a positive displacement pump, that...
A gear pump is a positive displacement pump, that must have a precise regulator in an engine oil pump application.
So my buddy didn't understand... nor listen. Puts an arbitrary, uncalibrated...
Forum:
Pontiac - Street
04-03-2018, 12:17 AM
77
DCI RAM AIR V CYLINDER HEADS
8,169
Posted By
STEELCITYFIREBIRD
http://www.dcimotorsports.com/ :cool:
:cool:
Forum:
Pontiac - Street
09-11-2017, 05:49 PM
4
What heater hose nipple?
503
Posted By
STEELCITYFIREBIRD
I don't know, but am curious of the reason for...
I don't know, but am curious of the reason for the spring and/or rubber.
I had a 77 GP and it had decent heat only a block from the house on the coldest of days.
Forum:
Pontiac - Street
04-11-2017, 10:19 PM
14
Shimming starter help
1,146
Posted By
STEELCITYFIREBIRD
As I push it, most of the time the teeth to not...
As I push it, most of the time the teeth to not align. Are you suppose to help the alignment by turning the gear a little as you push it toward the flywheel teeth? Is this ok?
Yes, that is why...
Forum:
Pontiac - Street
12-22-2016, 07:14 PM
12
Rear main seal leaking?
1,296
Posted By
STEELCITYFIREBIRD
The only mechanic in a can is the one actually in...
The only mechanic in a can is the one actually in the schitter. :D
Oil leaks run down hill, unless it is a pressurized leak or slung by a shaft or fan.
Forum:
Pontiac - Street
12-01-2016, 12:01 AM
107
Guys that lived the 60s and 70s era...please step in
4,291
Posted By
STEELCITYFIREBIRD
Fairbanks shift kit and converters....and FM...
Fairbanks shift kit and converters....and FM converters!
Air shocks, shock mounts were not designed/intended to bear continuous unsprung weight loads, only to dampen them. I did it, but I know...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
06:47 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
