Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 2
1
2
Showing results 1 to 25 of 34
Search took
0.02
seconds.
Search:
Posts Made By:
RocktimusPryme
Forum:
Pontiac - Street
04-10-2024, 04:38 PM
30
Best vacuum advance distributor to trigger MSD box.
2,138
Posted By
Singleton
I've had the small cap Progression distributor...
I've had the small cap Progression distributor for a couple years now, no issues with it in about 7-8k miles. I regularly use the anti-theft feature from the phone app when out and about, and when...
Forum:
Pontiac - Street
03-24-2024, 02:54 PM
23
Bad Squeal on throttle
1,053
Posted By
ZeGermanHam
I bought the aluminum pulleys from Ram Air Resto....
I bought the aluminum pulleys from Ram Air Resto. Took about a year to receive them at the time, but they work great on my 66 with PS, AC, high flow WP, and HD fan clutch. Gates belts, no squeal...
Forum:
Pontiac - Street
02-09-2024, 09:35 PM
91
Northwind vs Torker 2
4,109
Posted By
Gach
Definitely!
Definitely!
Forum:
Electrical Tech
01-03-2024, 07:43 PM
14
Fuse block repair.
1,227
Posted By
mgarblik
Before you test your parts car wiper motor, I...
Before you test your parts car wiper motor, I suggest you open it up and inspect it. They pack those old assemblies with grease that is almost solid now after 50+ years. Just cleaning the poor...
Forum:
Pontiac - Street
12-20-2023, 02:31 PM
20
Distributor gear
1,121
Posted By
GoatZillaRacing
Comp Cams recommends these too. They actually say...
Comp Cams recommends these too. They actually say not to use a composite gear with a high pressure pump. I've never had a composite gear fail but I must admit, these feel safer to install and they...
Forum:
THE LOBBY
12-18-2023, 04:21 PM
50
Harley Davidson Closing Plant Due to Declining Sales
6,294
Posted By
locomotivebreath
Jorts & white socks ! Man I hope that doesn’t...
Jorts & white socks ! Man I hope that doesn’t happen to me .
Forum:
Pontiac - Street
12-06-2023, 05:05 PM
18
77 TA brake upgrade simple
1,062
Posted By
JLMounce
Okay, so based on this, you're after a bit more...
Okay, so based on this, you're after a bit more repeatability.
Going to a disc setup in the rear will help some, but not as much as you likely need. These cars do most of their braking from the...
Forum:
Pontiac - Street
11-08-2023, 06:23 PM
79
Slack in center link, front end rebuild time?
4,094
Posted By
JLMounce
This. These cars didn't drive terribly when new....
This. These cars didn't drive terribly when new. When I hear people say you should throw a rack and pinion in them because they drive like crap otherwise just tells me they drove a 50+ year old car...
Forum:
Pontiac - Street
10-27-2023, 03:31 PM
23
I want to make a charcoal fuel vapor vent to reduce gasoline smell.
1,342
Posted By
OG68
Perhaps fuel is sloshing out of your vent hose...
Perhaps fuel is sloshing out of your vent hose when hard braking / accelerating.
Ames has a vent hose with a filter that may restrict fuel slosh
https://www.amesperf.com/parts/36579/
Forum:
Pontiac - Street
10-27-2023, 02:26 PM
23
1,342
Posted By
ID67goat
Just some feedback…….After installing basically...
Just some feedback…….After installing basically the same setup as you (Sniper, tanks inc, etc) I basically have no fuel smell in my garage anymore. Are you sure there is not a small leak somewhere...
Forum:
Pontiac - Street
10-27-2023, 01:21 PM
23
1,342
Posted By
Scarebird
I simply ran the vent tube line from the...
I simply ran the vent tube line from the fuel/vapor separator to the charcoal cannister, then into the airbox.
This is with fuel injection.
Forum:
Pontiac - Street
10-26-2023, 11:58 PM
23
1,342
Posted By
Mister Pontiac
One other thought, Rocktimus... My 74 Bonne...
My 74 Bonne has the canister and full setup you're describing, and it does not smell near as bad as all my other Pontiac's.
But the other thing it has is an...
Forum:
THE LOBBY
08-10-2023, 11:59 AM
27
Anybody into 65 and 67 Cadillacs?
1,224
Posted By
22 y.o. me and my 22 y.o....
22 y.o. me and my 22 y.o. Caddyhttps://uploads.tapatalk-cdn.com/20230810/af1ecf42922847efc959890c413641a2.jpg
Sent from my moto g stylus (2021) using Tapatalk
Forum:
61-66 Big Pontiac TECH
06-19-2023, 06:58 PM
14
1962 Catalina power steering box
1,174
Posted By
mgarblik
Yes, car-part.com is just a huge internet junk...
Yes, car-part.com is just a huge internet junk yard. But there was one yard that had 6-8 of them for $50.00. The notes said "tested" I have no real idea what that means. If I bought a wrecking...
Forum:
Pontiac - Street
06-19-2023, 10:38 AM
22
Quadrajet strange idle question
1,117
Posted By
Cliff R
I'd do the build yourself, saves money and in...
I'd do the build yourself, saves money and in almost all cases it probably just needs a good cleaning, lubrication, and some better parts installed to hold up in this new fuel.
The main causes of...
Forum:
Electrical Tech
05-27-2023, 06:52 PM
11
Fuel Gauge Wiring Question
747
Posted By
jamesq
If all else fails: ...
If all else fails:
https://www.ebay.com/itm/352501244864?hash=item5212b623c0:g:kH0AAOSwRLZT7MFq
I put this (and his new tank) in my 63 Safari and have no issues. I grounded the sender directly...
Forum:
Electrical Tech
05-26-2023, 09:30 AM
11
747
Posted By
Bill Hanlon
I believe 30 ohms when full, zero ohms when empty...
I believe 30 ohms when full, zero ohms when empty is correct for the '62. Jump the wire at the sending unit to ground and turn on the key. If the gauge still reads full the wire that runs from the ...
Forum:
Pontiac - Street
05-20-2023, 06:51 PM
16
2700 Mile Road Trip in Un-Improved '67 GTO
1,198
Posted By
Scarebird
It sounds like you had a wonderful trip and I am...
It sounds like you had a wonderful trip and I am glad you enjoyed it.
But please do not get hazy ideas, in as that quoted statement is complete nonsense.
Note over the decades even as more...
Forum:
Pontiac - Street
05-17-2023, 12:57 AM
55
Engine Displacement and Vehicle Weight
3,525
Posted By
Formulabruce
Check out this 1970 STOCK Chart. The ones I...
Check out this 1970 STOCK Chart. The ones I underlined are BOTH 2 bbl engines, with small valve heads. Probably around 9:1 engines.
NOTE; The RPMs at which Max Torque occurs.. That WILL get a Land...
Forum:
Pontiac - Street
05-15-2023, 02:41 PM
55
3,525
Posted By
b-man
Don’t be thinking big valves are needed for a...
Don’t be thinking big valves are needed for a 350, the stock ‘68 -‘70 350 heads with 1.96/1.66 valves are better suited for a torque engine and won’t give anything away in upper-RPM performance when...
Forum:
Pontiac - Street
05-15-2023, 02:08 PM
55
3,525
Posted By
Scarebird
I think it depends on what you want this wagon to...
I think it depends on what you want this wagon to do.
Unless the mileage is truly horrifying why not keep the Olds? It seems to do the job and is already there.
Forum:
Pontiac - Street
05-15-2023, 01:52 PM
55
3,525
Posted By
b-man
Stick an inexpensive running Pontiac 350 in it...
Stick an inexpensive running Pontiac 350 in it without hesitation. If a running 400 comes along use that, but there’s nothing wrong with a 350 which has about the same power as most of the 2-barrel...
Forum:
05-07-2023, 05:45 AM
6
I could use some pictures of 62 Cat rear suspension.
616
Posted By
Stuart
The rear drums were the same up through 1964. ...
The rear drums were the same up through 1964. Self adjusting was added in 1963. Here's a discussion about adding the self adjusting hardware: ...
Forum:
THE LOBBY
04-08-2023, 12:42 PM
16
New cruiser! 1962 Catalina Safari (x2)
1,061
Posted By
1965gp
Very cool! Looks similar to my 60 wagon when I...
Very cool! Looks similar to my 60 wagon when I bought it. Don’t be afraid to work that paint to get the patina look your after. I’ll be interested in what you find out about the seat covers. Are...
Forum:
Pontiac - Street
11-24-2022, 10:38 PM
8
Holley 4150 ID
785
Posted By
Tom Vaught
For sure an 830 cfm carb. Look on the...
Look on the metering blocks and see if the "modifier" dusted off the info on the top of the metering blocks (top right). Should look something like this #4781 (old 850...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
06:08 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
