Forum: 77-81 Firebird & Trans Am TECH
04-17-2024, 06:51 PM
Forum: Pontiac - Street
04-17-2024, 09:48 AM
04-17-2024, 09:46 AM
04-17-2024, 09:43 AM
04-03-2024, 10:44 PM
Forum: Pontiac - Race
04-03-2024, 10:39 PM
04-03-2024, 12:17 PM
Thanks it gives me a starting point. I have a...
Thanks it gives me a starting point. I have a couple of different adjustables we are going to use when we mock it up in the next week or two. I told him to get the rockers he is going to use also as...
04-01-2024, 09:22 AM
03-23-2024, 08:27 PM
03-19-2024, 03:33 PM
03-16-2024, 07:13 PM
Weight? Rear gears?
Th cam and intake and maybe...
Weight? Rear gears?
Th cam and intake and maybe even the 340 cfm heads killing the bottom end?
My 78 TA with my 0.030 over 2 bolt 455 320 CFM E heads and a 239/247 HFT Torker II and an 850 when it...
Forum: THE LOBBY
03-16-2024, 07:04 PM
Masters of the Air
For those of you into WWII history -which a lot of us Boomers grew up hearing from our parents- the new Apple series "Masters of the Air" produced by the same folks that brought the Band of Brothers,...
03-16-2024, 10:26 AM
03-13-2024, 11:04 PM
03-07-2024, 03:17 PM
What I did on stock mounts we used some 1/16"...
What I did on stock mounts we used some 1/16" plate and cut uut around where the bolt goes through and welded it to the metal "capturing" the bolt part clamshell so there is no movement. One on the...
03-01-2024, 05:21 PM
02-27-2024, 02:32 PM
To me the issue potentially is the "wall" shown...
To me the issue potentially is the "wall" shown in the other thread obstructing the main feed hole if nor ground down like Steve25 said. Otherwise that "wall" is the restrictive factor of oil getting...
02-26-2024, 05:58 PM
02-25-2024, 11:03 AM
02-23-2024, 02:48 PM
02-23-2024, 11:06 AM
02-23-2024, 10:57 AM
Why throwing soem higher octane race gas is no...
Why throwing soem higher octane race gas is no convertors or 100 octane race/unleaded and see if the motor picks up HP on the dyno or time in the 1/4. My zero deck RAIV 400 picked up 8 HP on the dyno...
02-22-2024, 07:58 PM
02-22-2024, 05:01 PM
02-22-2024, 11:25 AM
