Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 20
1
2
3
11
Last
Showing results 1 to 25 of 500
Search took
0.15
seconds.
Search:
Posts Made By:
Half-Inch Stud
Forum:
Pontiac - Street
04-24-2024, 02:23 PM
20
Cams Video
804
Posted By
grivera
Great video. While not the point of the video, ...
Great video. While not the point of the video, he mentioned was a 20% hp loss from flywheel to tires. Paul Carter pointed out using a percentage is flawed logic as it would mean an 500 hp engine...
Forum:
Pontiac - Street
04-24-2024, 07:27 AM
11
Got my grandson 4l60e broken down
407
Posted By
Cliff R
The 4L60E is a better unit than the early...
The 4L60E is a better unit than the early 700-4R/4L60's. The first big change to that transmission came in 1987 when the factory did about a dozen needed upgrades to the original design. The 4L60E's...
Forum:
Pontiac - Street
04-24-2024, 03:12 AM
20
Cams Video
804
Posted By
Dragncar
Yes he did. He told me about some Pontiac...
Yes he did. He told me about some Pontiac builders who put a 8500RPM spring for a engine that is done by 6500RPM. Some shop in "Ohio".
He said all that extra spring pressure contributed to breaking...
Forum:
Pontiac - Street
04-23-2024, 02:57 PM
20
Cams Video
804
Posted By
Dragncar
Its a good video. A detailed video mostly for...
Its a good video. A detailed video mostly for newbies.
There is stuff there (Vizard) even though he says there is not.
But he does use a flow sheet to pick a cam . I think thats a good idea.
The...
Forum:
Pontiac - Street
04-23-2024, 10:55 AM
20
Cams Video
804
Posted By
Steve C.
Regarding his point stating there is not really...
Regarding his point stating there is not really much gain when a port is maxed out in cfm air flow no matter how far you continue to open the valve it cannot flow any more air.
Regarding that, if...
Forum:
THE LOBBY
04-22-2024, 11:37 PM
4
Where is Moderator .......
660
Posted By
pont3
I was wondering about it too! He closed a thread...
I was wondering about it too! He closed a thread and I PM'd wondering what was against the rules on that particular thread. I didn't get a response and the thread was re-opened. Still haven't...
Forum:
Pontiac - Street
04-21-2024, 07:29 AM
6
Removing trans from 69GP
401
Posted By
steve25
Post 3 has the solution. To drop it out let...
To drop it out let both headers dangle on there bolts as far as possible and loosen up the collectors bolts.
If you put anti-seize on at lease one side of your header...
Forum:
Pontiac - Street
04-20-2024, 07:33 PM
6
401
Posted By
chiphead
Cut the dust cover ears off the trans or loosen...
Cut the dust cover ears off the trans or loosen the headers.
Forum:
Pontiac - Race
04-20-2024, 06:09 PM
11
Letting it loose tomorrow
576
Posted By
Mike S
Boy what a disappointing day. Went to Cecil...
Boy what a disappointing day. Went to Cecil county for the nostalgia race Waited close to 3 hrs for them to dry the track. Had a blow out on the trailer on 95 on the way down. Car got hung up getting...
Forum:
Pontiac - Street
04-19-2024, 10:34 PM
50
1000+ cfm from a Qjet
2,856
Posted By
Tim Corcoran
The small filter at the entrance of a Q-Jet is a...
The small filter at the entrance of a Q-Jet is a restriction even with the paper filter. There just isn't enough surface area in that tiny filter. I never run a filter there I use an external...
Forum:
Pontiac - Race
04-19-2024, 05:04 PM
11
576
Posted By
Mike S
For years I have detuned the car to go 10.00. After a lot of requests from my friends and fellow racers, I am going to run it all out tomorrow for the first race (bracket) this year.
Took 335lbs of...
Forum:
Pontiac - Street
04-19-2024, 08:25 AM
50
2,856
Posted By
steve25
Two big fuel bowls and two needles and seats can...
Two big fuel bowls and two needles and seats can at times solve the problem of not having a pump back at the tank purely due to the fuel volume on hand.
The root cause many times is the G force...
Forum:
Pontiac - Street
04-19-2024, 07:57 AM
50
2,856
Posted By
Cliff R
The information is both outdated and inaccurate. ...
Q-jets stopped using sintered bronze fuel filters in 1967.
4-6 psi fuel pressure???. Rochester moved the hinge pin forward in 1969. The...
Forum:
THE LOBBY
04-18-2024, 04:44 PM
12
RIP - Dickey Betts
529
Posted By
ftwmlp
Saw this on a news feed about 1:45 CDT. Spent...
Saw this on a news feed about 1:45 CDT. Spent many a night in my troubled youth listening to the Allman Brothers Band albums. They made great music together and Betts was a huge part of it.
RIP...
Forum:
THE LOBBY
04-18-2024, 04:34 PM
12
RIP - Dickey Betts
529
Posted By
Tempest
"listening to blue sky kicking back at the...
"listening to blue sky kicking back at the lake"................... well said
Rip Dickey
Forum:
Pontiac - Street
04-18-2024, 08:53 AM
50
2,856
Posted By
VCho455
Dhoo! You are correct 20.4! Thanks for the...
Dhoo! You are correct 20.4! Thanks for the correction.
I wanted to point out the devil is in the details with these kind of claims. But I did a poor job of it by not getting my details correct.
Forum:
Pontiac - Street
04-18-2024, 06:31 AM
50
2,856
Posted By
steve25
With any motor the bottom line is that at full...
With any motor the bottom line is that at full throttle , max rpm and under load a vacuum gauge will tell you if you need a higher flowing carb(s) or not.
Also too large of a carb can undue what...
Forum:
Pontiac - Street
04-17-2024, 09:48 AM
50
2,856
Posted By
or blowing the needle off the seat as the float...
or blowing the needle off the seat as the float leverage is hard to hold that much pressure with the larger needle.
Forum:
Pontiac - Street
04-16-2024, 05:21 PM
50
2,856
Posted By
70GS455
Ran across this article from David Vizard's "How to Build Horsepower" Vol 2. They discuss modifications on a Quadrajet to get to 1090 CFM, as measured by a flow bench.
Forum:
THE LOBBY
04-13-2024, 10:23 PM
16
A First For Me.
859
Posted By
fyrffytr1
A First For Me.
In 73 + years on God's earth I was met with a first last weekend. My buddies and I were relic hunting in a plowed field when one of them said he had something to show me. As we approached the planted...
Forum:
Pontiac - Street
04-13-2024, 02:27 AM
6
Q jet info for all, power piston spring rating
544
Posted By
gto4ben
I got tired of guessing what performance the...
I got tired of guessing what performance the commercially available PP springs have so I created a spreadsheet that takes free length, outer dia., coil count, and wire diameter to calculate the...
Forum:
Pontiac - Street
04-10-2024, 12:01 PM
12
Earth locations
589
Posted By
HWYSTR455
Under the dash, I use the lower brace of cowl...
Under the dash, I use the lower brace of cowl where the dash attaches by driver door to ground everything under the dash. Did a rivet-nut with a stud, and everything goes there. It will feed off the...
Forum:
Pontiac - Street
04-10-2024, 07:01 AM
10
th 400 transmission
654
Posted By
Cliff R
Yep, it was spending WAY too much time sitting on...
Yep, it was spending WAY too much time sitting on my lift and not enough time being driven. I really don't miss it much, had lots of fun with the car over the years, but since retiring I've changed...
Forum:
THE LOBBY
04-09-2024, 02:29 PM
13
dry ice blasting
800
Posted By
1967gto1
My 80 z28 undercarriage was covered in...
My 80 z28 undercarriage was covered in rustproofing. I used mineral spirits and old cut up bath towels. I don't know how many hours it took, but it worked great. Took it right down to the paint. I...
Forum:
Pontiac - Street
04-08-2024, 08:23 AM
17
Cylinder Offset Changes Everything
1,018
Posted By
steve25
X72GPX it’s due to first off the longer strokes...
X72GPX it’s due to first off the longer strokes that Pontiacs have then other brands on there street production motors.
For example a 455 Buick has a 3.90” stroke as compared to the Pontiac 455...
Page 1 of 20
1
2
3
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
07:12 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
