68 Gas Gauge
Need a 68 gas gauge....rebuilding dash and the old one is rough....
Fuel gauge.
3 Attachment(s)
This one?
Standard....thank you
Exactly Pete...I'm shopping for the best looking one I can find...I hope to never upgrade the dash again!
email dpowell1166@gmail.com
That '68 instrument panel is a bugger to R&R ain't it? |
Gas gauge
I also have a spare I can part with but won’t be able to get to it until this COVID thing is over. . . .
I am pretty sure I have a nice one and can look it up this evening and report back to you. Is an F body the same as an A body for this gage ? Pretty sure what I have is out of a 68 Firebird. Please PM me if you are still in need.
Tim john--- |
Understatement of the year....! But we will succeed
Right on....keep me in mind and be safe
Thanks Tim (john)
I'd bet most of the used gauges you'll find will be aged and the marks will be discolored to some degree. I thought my original was in perfect condition until I looked closer, you can see how it's discolored compared the gauge face. For whatever reason the smaller fuel, oil and temp gauges seem to discolor faster than the faces. You may consider having Pete Serio restore your original depending on your expectations. http://forums.maxperformanceinc.com/...1&d=1585244748 |
I have a plan in my head to bench test my whole dash unit before installing it .... hook up the fuel sending unit, temp sensor, oil pressure sensor .... whatever I can. Try to power it up and check as much as I can .... is this possible?
3 Attachment(s)
According to the box I have mine in, it was removed from a 1968 Firebird, it is really nice but does not appear to be correct for your application and does not match Pete's photos. Sorry I was not able to help you out.
Tim john--- |
Luckily I'm just dealing with idiot lights. Would be nice if I could power up the entire dash from a single 12V input ... but I'm sure it's got a different power wire for every function. I'll probably get blisters from the alligator clips.
