Wanted 66' pulleys
Need the following pulleys for a 1966 OHC
Balancer pulley Water pump pulley Alternator double groove pulley |
do you have any nos. i have a tub of pullys
I dont have any maybe someone here can post #s
Pulleys needed are for powersteering
Bolt on pulley to balancer Double grooved w/p pulley |
9778558XP for the Duel fan pulley,
sorry not have a # on the 1BC HB bolt on pulley. |
I have alternator pulleys
Oh yea, also needed if you run PS/AC
Duel Groove Alt Pulley #1964758 (Delco) |
I didn't know they made these new. Part # is listed as a replacement I wonder if its the same dimension as the original?
I dont have a stock 66' to compare to. Thanks for posting that link PMD1969 |
pulleys
2 Attachment(s)
Here is the difference between the 66-67 and 68-69 double pulley. Left pulley is 66 right pulley is 68 1964758 Notice inner groove is almost identicle. outer groove is in a slightly different location. It will cause the belt to come off or flip at high RPM. The pulley shown in the earlier post is the same as the 1964758, but aftermarket. I can supply that new shipped for $25.00, but it is not right for the 1966 or 1967. I do not know of anyone that supplies the 66-67 pulley new.
Respectfully disagree...
or at least as good as when it left the factory ;) I drive her a lot and not very nicely I might add :D |
Thanks for the pics as I have not seen a assy unit in person. |
That alignment looks good.
It was no issue and no added spacers.
I will add; I run the oem cast PS pulley as well. Very hard to come by but it too as you can see has the wider center spacing. |
I received my 66' balancer today and noticed that it looked like a pulley may have been mounted so I called and they have the pulley available that bolts to the balancer. They want $75.00 for the pulley I know that seems high but I cant find one anywhere. So its prob worth the price right? The part # for the 1bbl balancer pulley they have is 9783100.
They also have a complete 66' Powersteering pump with the htf pulley also a little high in price but very hard to find. |
If it's available and no other member has one for sale, then you need to grab them. You may pay a premium, which is unfortunate. But a business needs to charge more.
You can run the part number in the PY parts lookup. It comes up as a '66 1bbl, driving only one accessory. |
Would they have been the ones from Franks?
If so then yes priced right at the top of the scale, but where are you going to find another? |
Anyone have the Delco part number for the 66 double alt pulley?
