Motor plates
I am new to this scene mainly because I build street cars. I am curious of the various motor plate setups offered for pontiacs. All Pontiac has a front and mid plate arrangement I am looking at. Any thoughts?
Here's the All Pontiac plates, plus a few more. :)
http://www.allpontiac.com/chassis.html http://butlerperformance.com/product...otorPlates.htm http://tinindianperformance.com/Pont...r%20Plates.htm http://www.spottsperformance.com/mounting http://www.campbellenterprises.com/mid-motor-plate.php https://www.cachassisworks.com/p-137...-midplate.aspx |
I can help. What are you building?
I also use one of their front plates only on my wife's car with the stock motor mounts just to give a little more support on the block and to act as a torque limiter instead of using chains, turnbuckles, straps, etc. |
AP front plate, mid plate, poly trans mount & limiters to control longitudinal movement.
Any decent custom water jet business can cut you exactly what you need.
2 Attachment(s)
I went with elephant ears instead of a front motor plate. I have a poly trans mount, and two limiters on the front of the engine. No mid-plate.
Thanks every one for the input, we are going to most likely run the all Pontiac setup. If not I am not opposed to making my own.
Props
I've seen your '65 at the Del Mar Goodguys show. VERY nicely done! I may borrow your idea for the steering linkage. Did you have any issues with it?
