race parts
5 Attachment(s)
Pair of AP header flanges that were separated for custom removable header tubes. I decided to go with stainless and did not use these. 5/16" thick. 2 1/8" tubes. $65.00 shipped
New Nitrous Pro Flow bottle warmer. $100.00 shipped Ultradyne cam grind number: 324/336 R114. Cam made 900+hp in a 541 Rebuilt Crower lifters number 66295H. Offset intake. Lifters have 7 passes on them since rebuilt Cloyes double roller timing chain. Has 7 passes on since new. $700.00 plus shipping New, never used wet sump external oil pump oil pan with belt drive front on it. $400.00 plus shipping AED 750 HO carb (4150) that was used on my dads car for engine break-in. couldn't use it with ram air setup. Build date on carb was 1/29/99 but was not used until March 2010. I have build/spec sheet from AED. Used for start ups only for a few months then removed and put on shelf. $300.00 plus shipping. |
2 Attachment(s)
more pictures
Is that a custom number on the cam? Can you give more specs: lobe lift, duration, etc.
Is the cam hydro or solid? Thanks, Mark |
Might be interested in the lifters if you sell the cam seperately.
2 Attachment(s)
Mark |
Pm sent
header flanges sold
Aed carb
pm sent
pm replied
PM sent on pan
AED carb
Jim did you receive my pm from 9:14 last night?
sent via email.
Aed carb
Pm sent
carb and bottle warmer sold
AED carb
Thanks Jim,currently in New Orleans have someone to receive the package in jersey.
Hank |
