'67 Lemans LS2 Conversion
We have a '67 lemans convertible (326) automatic and are wanting to pull it and drop in a LS2 from an '05 GTO automatic. Who has done this, what are the obstacles and what conversion kits are available? Thanks,
I would suggest you reach out to a company called "Speartech", they will re-work the factory wire harness for a stand alone operation in your 67. They will also re-flash the factory computer for a stand alone, removing all the unnecessary data. This is all scienced out. They are excellent to work with and have been very helpful with any and all questions I had/have. All wires are clearly labeled when you get the computer and harness back.
Tim john--- |
A good lead for the electronics were given. How about the engine mounts, cros-member, a/c hookup, cruise control, etc? any help with these and more?
All the swap info you will need http://www.pro-touring.com/forums/75-The-LSX-Forum
