lifter bore hone wanted to rent
anyone have a bhj or sunnen lifter bore hone I could rent this fall for a weekend? thanks in advance.
If you do not have to remove anything but high spots from scratches then a brake cylinder Hone will work.
Hone
Needed to hone a new set of bronze inserts in an ia2 block to final size.
Well you really want a shop to do that as each Bore being Honded needs to be constantly flushed with lube/ coolant that's filtered , then recirculated just like when boring a cylinder.
hone
I have a set up to lube the hone and filter and recycle the lube/coolant. I am in western va and the closest shop to me that can do the honing is about a 4 hour drive each way. I would have no issue honing them I just cant justify buying the tool to do one set of bushings. This will be the first set ive had to hone in over 25 years of machining and engine building. I had a guy local who could do them but he is 73 years old and is no longer working in his shop.
