Rally II wheels Backspacing measument
Can anyone confirm or not if the Pontiac Rally II wheels that's on the sec gen cars are 4 or 4 1/2 inch backspace looking for verification...thanks
The set I have were off a 73Formula. They looked to me like 4.25 when I was measuring.
So your saying 4 1/4 Inch...hmmm
The last ones I measured were 4-3/8” or a tad more.
Definitely not 4”. |
yeah definetely not four. I was thinking they were 4 and a quarter but they might have been a little more. Its harder to measure with tires mounted on the wheels.
My 15 inch HM code rally’s (can’t remember year) are 4 3/8
If you can have what you want, try to get the most, I doubt it will be over five..
2 Attachment(s)
Just measured a 15x7 it's about 3 3/4 inch definitely under 4
You sure you’re not measuring a 6” wheel?
No way any factory 15x7 measures less than 4-3/8”. Most aftermarket ones are 4”. |
2 Attachment(s)
Heres the rim measured outside lip to outside lip then inside to inside
Aren't the rims stamped ??? 15x??? Looks like a 6inch your right... Didn't know they can on 15x6. Thought that was 14 inch |
That’s a 6” rim. Bead to bead is how they’re measured.
Wheel diameter is also measured at the tire mounting bead, not the rim edges. |
Yeah I did not know they came 15x6 learned something new thanks bman the search continues
