Rotor help needed
Ok, i had 11" rotors on my 66 Gto, but found out they were "B" body spindles, so i have the parts switch to go back to stock...............im thinking all i need to do is get new rotors and calipers, think i need Timken Set 2 and Set 6 bearings...........looked up on the wheel seal and it says i need the Timken 8705 wheel seal, this is where im confused on the seal i took out it says Timken 8871..........which looks like for a 69 camaro.??
Wondering if anyone has recently replaced the rotors with the 69-72 "A" body stuff, are these the correct numbers i should be getting.................if not could you direct me in the right direction. Thanks Rich |
Timken 8705S is the correct front seals. This is what I used on my 66 with the later A body front disc setup.
What spindles are you going to use?
Thanks GTO TEX, thats what i will get.
Scarebird, i did have the "B" spindles on the car, switched everything over to the "A" body stuff..............have a good new year guys. Rich |
Far as I'm concerned--and not everyone will agree--you were better-off with the B-body steering knuckle. (Assuming this is the "Tall Spindle"-style disc brake conversion.)
WHICH "B-body" is this from? |
Rich |
