Can I get help with goodmark part numbers?
I am making a list of parts I will be ordering for my car;
I have been told I need to find the goodmark part numbers and at this time there is one part in particular that I cannot seem to find. The main part right now that I cannot seem to find is what I would call the inner rear tail panel. It connects the the end of the trunk floor and drops down to the bottom of the outer rear tail panel. I think I found it on the Classic Industries website, but it says it's a Camaro/Firebird part, and I thought the Firebird one was specific. rear inner tail panel https://content.speedwaymotors.com/P...c54fb5e179.jpg Interestingly they call it a "rear frame cross member" or "rear crossrail". Is this a Camaro part? If so, is the Firebird one not available? In the course of my search I have found several listings on Classic Industries pages that I could not find on the Goodmark page; Aren't all these parts manufactured by Goodmark? Here are one example of parts that I found on CI, but not on Goodmark: Trunk assembly with frame rails https://www.autopartsdb.net/assets/i.../14943W_V2.JPG I will probably not be going this route, but it was a part I was considering; My hesitation is that it has the rear seat section to top of trunk that on my car is solid - I was thinking that I would weld the floor to this section at the rear seats, another strike against it, is the trunk floor appears to be the one that is setup for a gas tank with the eveap system - since mine in not Van Nuys car, mine shouldn't have that. While we're in this area, I have been inspecting my rear frames and thought that you could buy front and rear halves or the whole thing; Mine are bad at the front where they connect to the floor, but when they curve to go up behind the seat they appear to be fine from that point rearward. I won't know for sure until I get the very rear sections blasted and clean if the rear most part is bad enough to deem replacement necessary, but my hunch is that it's fine. Is a front section not available by itself? If so, will I have to buy the whole assembly to get the front section? Are these parts being marketed by CI as OER parts not Goodmark? Or are Goodmark and OER competitors? I had thought OER was packaging parts for retail sale, while Goodmark wasn't really retail - they were more for the auto repair industry. Also, while I have you on the subject of available panels/assemblies, a local suggested that he thought he saw a full floor with rockers - does such a thing exist? - I do not recall hearing of this. Thank you very much in advance for anything you can share to assist me. |
Perhaps a match on the cross rail.. My 70 Firebird only part CD shows the GM part as 9826894.. Googling that number brought up the Goodmark part GMK402179070.. the image matches what you posted here.
Thank you very much!!
I sure couldn't fibd it on the goodmark site without that number!! |
I've just sat down again to write out my list, and I have been looking at trunk floors again.
It looks like the full trunk floor (GMK402172570S) has the evap cannister opening, unlike the partial floor, and there's really no way around this considering my trunk floor ends are rusted, and probably don't have sufficient metal to weld to the trunk drop offs. At this time, I was planning on getting: - full frame rails ($568; $284 x 2) - a full trunk floor ($525) the trunk floor braces ($142) because the very back of them are rotten and will at least need fabrication/repairs. If I use online prices, the piecemeal cost will be about $1,232 - so I am now back to contemplating the full trunk assembly; My thoughts are that the marginal price increase would be justified by less assembly time. This assembly also appears to have the rear tail panel support brackets (not included with full floor) and jack assembly support brackets (included with full floor) all attached. I don't believe I need either of these, but if I'm going in this deep the assembly means I won't have to cut off and reattach my old ones, so that's just that much less work needed. Can someone please tell me if Goodmark has a number for this? Thanks again!! |
oh!!
is this not a Goodmark assembly? https://www.classicindustries.com/pr...arts/c340.html This one has the trunk floor with the braces (top and bottom), and jack assembly mounts all together. |
Golden Leaf Automotive Parts
Hey unruhjonny not sure if you know about these guys. check out they catalog on page 21 for the complete trunk assembly. Not sure how it fit because i didn't install mine yet but it looks pretty good https://www.goldenleafautomotive.com...irebirdTransAm
Thanks for the tip;
Shipping from Ontario would be brutal. There is a local distributor for Goodmark that my brother has an account with - which is why I am looking for Goodmark part numbers; If I use this local company, I don't have to worry about shipping. |
