Window glass
My next project to finish is a 69 and I'm in the process of deciding to go with coded or non-coded glass. The car had been "restored" before and all of the glass, but one 1/4 glass, replaced with unmarked glass. (The glass needs to be replaced)
The oddity is that the glass bears an Oct 69 code -- which is for 70, when no 1/4 window used. The car has a Dec. 68 build date. Does anyone have a car built in Dec. with original clear/non tint glass that they could provide me pics of the front, door etc. date codes? Sent from my SM-A125U using Tapatalk |
since it bounced back and forth between LOF and PPG,which is correct for your car?
My 67 used LOF and my 68 used PPG. Contact auto city Classics and ask for Andy,he will tell you how to decode and steer you in right direction. 69 production carried into 1970. |
I know about the codes. I've been in contact with Todd over there. My 1/4 glass is LOF.
I just want to see what code others have in the same time frame, for reference. Sent from my SM-A125U using Tapatalk |
Anyone to post some pics?
Might should post the build date of your car from the cowl tag .
