7 blade clutch fan
when years did these come on the trans am ,can i install one on my 72 formula.my friend has on for sale
my has a/c |
found this photo ,it is Bobs 1972 455 .did the 7 blades only come with the 455
2 Attachment(s)
That "looks" like it will work if you are using the common mid 70's brackets, some earlier brkts may be different. Maybe someone else can confirm based on the part# of the fan but from my experience any 350-455 mid 70's 7 blade fan will work on most model cars including 2nd gen firebirds.
Also should be easy to test fit it, if it sits about half way in/out of the shroud it will work. |
That looks correct for the Firebird. Have him look for the stamping on the clutch mounting face. https://forums.maxperformanceinc.com...d.php?t=806240 |
I put one of these on my ‘73;
As I recall, I pulled it off a Ponti-yacht. the biggest PITA was getting the mounting studs off the car donating the clutch fan - then installing them on the ‘73; Radiators and knuckles don’t get along very well! |
