I use a 8 clutch setup using the Hi-Energy frictions and thick steels. It seems to work very well. I have one behind a 502 Ramjet for about a yr now, maybe longer.
The stock clutch doesn't have enough area IMO, so you need to add to the count, but there is a limit to what you can do, and you MUST keep the steels thick. I mix the .095 and .106" to get what I need.
