The hood location does a really good job for collecting air for the turbos as the turbos need minimum restriction on the inlet side for best performance. It is like drawing out of a very large room with a vacuum cleaner hose.
If you put a scoop on the inlets or screens you would disrupt the clean airflow to the compressor wheels.
The two smaller lines from the radiator on the right side of John Welters car went to the engine. The large line from the collection tank is not hooked to the radiator. Two different sized lines if you look closely.
Tom Vaught
