Are the 2 flaps you took out from the ends, leaving the center one in place?
Do the pivot pins just pull out to release them?
The bigger one has a foam seal and the end one has a rubber seal with staples, the center one I cant tell
It looks like the inside of the box did not have any paint on it from factory and the outside was a semi flat black. Was this finish the same as the top of the dash?
