Originally Posted by LMSRACER
Longevity....
Years ago when I Bracket Raced regularly, I would freshen my engine every year. What I found was that the coated piston tops could be cleaned in a parts washer with 0000 steel wool for three or four rebuilds before the coating would begin to wear through on the edges. The Pistons always looked like new once the carbon was removed.
I never replaced a piston unless the ring groove to ring clearance (Radial Clearance) got too great.
Larry S.
How about if a skirt collapsed? You would only have to replace a piston for the same reasons the rest of us would....just sayin. I'm glad your happy with the coatings, After my skirt clearance wears....I'll try some
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
