[QUOTE=JLMounce;5585765]Right. If lobe lift is a function of decreasing the base circle, what what lobe lifts do you start running into this issue?
The SD Performance OF grind for example is listed at .578/.582 gross lift with 1.5 ratio rockers. It's lobe lift on the exhaust would be .388[/QUOTE]
Which would be enough to be a problem. These cams I'm dealing with now have lobe lifts of .350"-.370".
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
