View Single Post
  #50
Old 06-06-2016, 10:43 PM
Originally Posted by gtofreek View Post
What's important to note of is if the oil hole in the block will line up with the oil band in the lifter, when the lifter is on the base circle. I can't remember how Olds is, but Pontiac just has a 1/4" hole, closer to the top, than the bottom. Because of this, the band drops below the hole at base circle. This is the critical time the lifter needs to refill itself. If the Olds oil hole lines up with the oil band at base circle, you're golden!
Question Paul,
Why does everyone tout about Johnson lifters being the best to get if the oil band is in the wrong location for a Pontiac application. Or is it?
I've never heard that complaint before yet from the sound of this entire thread no one makes a correct Pontiac lifter.....
