Originally Posted by GP67
Been busy.
I pulled the valve cover and the timing chain is loose to the point I can lift it up off the sprocket teeth. Droops below the top chain guide say 1/2 inch or so.
That can't be good.
The next thing I'm going to is:
(And correct me if I'm doing anything wrong plz).
1. Check for loose rockers.
2. Turn the crankshaft to put cylinder #1 at TDC which will close both the intake and exhaust valves.
Only if you are at TDC Compression. TDC Exhaust will assure both valves are slightly open.
3. Add air pressure through spark plug orifice and check for air at the throttle-body and exhaust.
And check the radiator for bubbles, and check the valve cover for excess blow-by.
An actual leakdown tester will put numbers to the cylinder leakage. If you've used the leakdown tester on "known-good" engines, you'll have a guide to what's acceptable leakage, and what's excessive. Rings always leak. Valves, castings, and gaskets shouldn't.
