Originally Posted by johnta1
Some interior harnesses (at least 70 Firebird) had extra circuits that were taped up if not used.
I'd try checking continuity from the fuse end and see where the other end is? And where it might go?
Do you have the PHS? What does it show for electrical options?
Yes I have the PHS and the build sheet, everything that should be there is there for options. The only parts I think I might be missing is a carb idle solenoid or TCS set up.
