Originally Posted by 60sstuff
Anti-Stall dash pot.
The MPC shows T/8 Auto 2bbl. #7020587
T/8 Auto 4bbl. #7019951
NOS 4bbl. shown below and how it looks on my car.
When the car tends to die, the plunger pushes out against the carb lever to kick up the idle.
Works as designed.
Chris.
Where does the vacuum hose plug into? The back of the carb center port block, or the stud port?
How should it be adjusted? So the screw is touching the throttle arm with the engine off, choke high idle cam off?
