My 78 had little cracks at the back of the door-window-C pillar. Thin coat of filler. Just pulling it in and out of the body shop started cracking. Pulled out all the factory lead there, There were only 3 spot welds holding the back of the top to the C pillar! Solid weld and no cracks even after alot of autocrossing and low 11 high 10 drag strip passes. I did add the old Moroso subframe connectors. They hang down lower than most of the options now.
