Originally Posted by Singleton
Curious as to the some of the actual methods to dressing the gears before assembly. What's your procedure?
Good question. I'm similarly curious why the cam manufacturers deliver finishes on the gears that cause high wear rates? They grind the lobes... can't they debur or peen the gears? Seems like they assume a break-in period that doesn't go well with composite distributor gears?
