That 2000-6000rpm range may be close in a 350 build but that cam will be DONE before 5000rpm's in a 455 build.
I didn't see the compression ratio mentioned but the smallest cam I'd even think about putting in a well thought out 455 build would be 230 @ .050" and at least 280 @ .006".....FWIW......
