View Single Post
Old 03-18-2023, 10:02 AM
lrust's Avatar
lrust lrust is offline
Default Using Points Distributor with non-factory wiring harness?
Anyone have a suggestion on how to safely wire and set up the reduced (<12V) voltage level needed for a points set up when I only have 12V available? Factory wiring harness is not available in the car and I want to use the points system to run a points compatible tach. Thx.
