Originally Posted by tekuhn
The mechanical clutch linkage is unusual, The pedal rotates a piece that crosses through the brake pedal and pulls rather than pushes a rod that angles down through the floor. It’s hard to describe, but I can provide pictures Monday if you’d like them.
Thanks but I don't need them. This car has a hydraulic clutch, tko600 trans and straight axle rear end so differs from an original setup. I need to leave the assembly that pushes the rod into the clutch master cylinder as is and just find a way to move the brake and clutch pedals away from the gas pedal and then create some distance between them.
