Thanks Jack!
I did not have time to make another Exh flowtest with a tube on the end of the runner, but I will do so by weeks end.
Jack in regards to your previous question about the Intake valve notch being used / simulated for a flow test what I do is slide the head over on the Bore adapter so as to get the edge of the chamber right to the OD / edge of the Bore.
