When you say "you can not pull to much vacuum", can you explain a little bit ?
This is my first V pump and it pulls at least 10 in foot-braking it at 2000RPM. I do not know how high it goes down the track because its only been down the track twice and I did not have a gauge on the cowl where I can see it. I do now.
I do not have a regulator on my pump and the Moroso tech told me you do not want anymore than 12-15 in. going down the track. He says you can pull oil away from your pins.
The good regulator is kind of expensive and if I did not have to buy it that would be great.
