View Single Post
Old 04-02-2024, 03:51 PM
Skip Fix Skip Fix is online now
I can't see it making that much difference either as we are all just guessing what each motor really needs for pressure for each cylinder-more theoretical for those that HAVE to have everything identical. Shim it if that does not kill distance to coil bind you need. Also measure every valve's IH as sometimes they are a hair different and you can giggle springs and pressures a little base on that.
