View Single Post
Old 04-23-2024, 12:18 PM
78w72 78w72 is offline
Originally Posted by 65 Lamnas View Post
I did something similar, but my method was to use a piece of 5/8"plastic round stock. Cut a piece about 1" long, drilled a 1/4" through hole and stuffed it into the short heater hose from the head to the core.
Thats a good way to do it too, I used the stainless washer for corrosion & heat resistance, wasnt sure if plastic would stand up to the heat for too long.
The AN fitting was probably enough of a restriction at ~3/8-7/16 ID.
