View Single Post
Old 04-23-2024, 12:25 PM
JLMounce JLMounce is offline
Check your factory heater core inlet. Some of these are designed as a flow restriction to begin with. If the inlet nipple is dimpled, this creates the flow restriction to stop the wall of fluid to the core on hard acceleration. You can add additional inline restriction that is talked about already, but you may not need to.
-Jason
1969 Pontiac Firebird
