That's them. There is minimal adjustment available by loosening a few of them and lifting nose cover to suit or straighten. Of course limited by hole clearance, can be enlarged, covered by washer. The fibreglass threads aren't strong so screw up firm only. It doesn't replace proper panel alignment, just tweaking.
You can also add a washer under the the radiator support to each location that mount the hood latch to bring it down in the centre, allowing hood flex to stay at existing corner heights.
